This weekend I drove hundreds of miles, took the opportunity to do some mileage tuning and had an unexpected observation; after dialing-in the VE table for freeway crusing, I ran two tests:
1) I entered 0.97 EQR in the commanded AFR table in my "cruising" cells, flashed the truck, and drove an hour on cruise control at 73-mph.
2) I entered 1.01 EQR in the commanded AFR table in my "cruising" cells, flashed the truck, and drove another hour on cruise control at 73-mph.
Both tests were driven in Kansas on I-35 - terrain wasn't much of a factor; head wind during that two hours was the same also, weather was consistent the whole afternoon. I was looking forward to the 'lean cruise' AFR table (test #1) to get better economy than the 'rich cruise' test, but the opposite happened - I got worse mileage when commanding 0.97 EQR than 1.01 EQR, almost 1/2-MPG worse in fact.
But I noticed something else as well, the MAP readings during cruise when on my 'rich' commanded AFR table were consistently lower than during the lean cruise run; the motor ran with noticeably more vacuum, and more 'pep' & was much more responsive. Which then made me remember tuning carburation back in the day, we would dial-in jetting by using a vacuum gauge and adjusting mixture with jets until we read the highest possible cruise vacuum, and that was usually the 'calibration' where the motor would have the crispest throttle response/transitions as well as pretty good economy too.
So the question I have is: with all the best-practice of using a wideband for tuning feedback, has anyone also tuned using MAP feedback, i.e. tuning for lowest/best MAP reading during cruise?
Mr. P.
Advanced question - I wonder if the motor will have lowest MAP when you have found MBT?
