Any update when the speed limiter function on the 2011 VE will be fixed ?
2011 VE SSV 419 + CAM + Whipple 2.9FF SC + PPV front struts + Bilstein rear shocks + 6L90E with single piece carbon fiber prop
Hi Izak,
As per my last email to you with regards to the 2011 speed limiter issue you saw; looking into this further is going to have to wait until the Cummins release is out. There is a building list of "things" to be progressed which are all awaiting the Cummins release. In terms of existing priority there are a few items ahead of looking into the 2011 speed limiter issue (things like A50 flash support for instance).
Andrew
EFILive Crew
Thanks for the update.
Was just wondering, as apparently ..tuners can set the limit
Fixed in build 167 - thanks guys
does this fix the issue for the earlier models hitting a fuel cut even with all the limiters maxxed out?
No, this was specific to 2010 models.
