Right I have some uprated Bosch injectors 0-280-155-968. There is the details in the stick on the rates (Not sure there right as I have found other sites rating them high both spec and real. )
Either way what ever is the correct data how do I convert this data in to the right tables??
Also, am i right in saying by doing an Auto VE run should provide proof that my injectors are flowing at similar rates as the BEN Corrected AFR against commanded should be within .01ish still???
Antony
