Results 1 to 4 of 4
Thread: 2-3 shift flare and TCC wont lock. Tune Inside
    Apr 2011
    Default 2-3 shift flare and TCC wont lock. Tune Inside
    This is a tune I have been working on. It started in the hands of another tuner, and I've been trying to help the owner of the car sort out some issues.
    Can you guys take a look and see if there is anything I should correct.
    Issues at present are:
    2-3 shift flare.
    It doesnt hit the limiter, but for example it will be commanded at 6400 and flare to 7100 before completing...
    I've dealt with this before on a 4L60E and it turned out to be a mechanical issue. I've talked to other tuners and that's what it almost always turns out to be, but I want to rule out any possible cause in the tune for the owners peace of mind.
    We are going to install a line pressure gauge and see if the pressure drops right before the 2-3 shift commanded RPM, I suspect it does and that's why it flares.
    TCC will not lock, or stay locked at highway speeds. Sometimes it will lock around 55-60mph. When speed is increased to 70-75, it will stay locked for 3-5 minutes then unlock and refuse to lock again. It will lock just fine with the EFI Live scan tool.
    It looks as if the other tuner has already maxed out the areas in the misfire tables that could cause this. What else could it be?
    Thanks a bunch for looking.
    Download shaw_customos_N20_ONLY.tun from FileFactory.com
    Hi gregrob,
    I'm failing downloading your file... can you attach it, see post #2 here: Hosting-an-Image
    Apr 2011
    I tried that and it wont upload. I just get an exclamation point when I click upload and it does nothing.
    Apr 2011
    Ok guys, I uploaded the file to me website (had FTP issues or I would have last night).
    forddieselpower.com/grfiles/shaw_customos_N20_ONLY.tun
    I also posted this tune in the COS section as I'm having some issues. thanks for any feedback!
    Greg
  1. 4L80 no tcc lock up
    By E.R. Racing in forum Vortec V6/V8 Specific
    Last Post: October 13th, 2009, 05:35 PM
  2. 1-2 Shift Flare over half throttle...B@STARD Setup!
    By ssvolvo in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 8th, 2009, 10:24 AM
  3. TCC lock up
    By jegauto in forum Allison 5 & 6 Speed
    Last Post: October 6th, 2008, 03:57 PM
  4. tcc lock up to soon
    By kjohns18 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: June 5th, 2008, 02:32 PM
  5. Car Wont Idle And Runs Rich At Idle ( Tune Inside)
    By mikeyayell in forum Gen III V8 Specific
    Last Post: January 8th, 2008, 04:17 PM
