Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 74
Thread: Issues on the first day with efi live...
  1. #11
    Can you please send your 'returned to stock' file to support@efilive.com , obviously if it's not being returned to stock 100% then we have a problem
  2. #12
    Quote Originally Posted by CIDRAUGHN View Post
    However, when I read the file and make the slightest change to it, it says that the values are out of range, and that efi live will not flash it.
    Can you please send that file to me at paul@efilive.com
    The scan tool does work partially, however, on both trucks.
    What part(s) of the scan tool do not work?
  3. #13
    Quote Originally Posted by skneeland View Post
    same problem here
    getting "script file not supported" when i try to read the ECM
    emailing you the trace files as well
    Are you trying to read it using V8 pass-thru reading to a PC, or using the FlashScan as a stand-alone device?
    If you're using FlashScan as a stand-alone device, make sure you have downloaded and installed the V8 software and that you have updated the script files on your FlashScan device and that the FlashScan device's firmware is up to date with the latest firmware from the V8 software.
  4. #14
    Junior Member CIDRAUGHN's Avatar
    Mar 2011
    Paul[/QUOTE]
    I am having problems accessing some of the PIDs such as commanded RP, and actual RP. That is most of the problem that I am having.
    06 Dodge RCLB 2500 5.9L Hamilton, Maxxspool, Wicked Diesels, Bullseye Power, Industrial Injection, South Bend Clutch, Amsoil, K&N, ARP,EFILive, T&C Diesel, ATS, GDP...
  5. #15
    Mar 2011
    email with stock tune sent.
  6. #16
    Lifetime Member FUBAR's Avatar
    Feb 2011
    Mine worked!!
    06 LBZ, EFILive
  7. #17
    Jun 2011
    Email sent. For what it's worth, I have heard of trucks tuned with a bullydog being a bit more difficult to return to stock.
  8. #18
    Mar 2011
    Mine has had smarty s06 and smarty SSR on it, however it is returned to stock, and the truck that has read successfully has had both s06 and SSR on it as well.
  9. #19
    Mar 2011
    Ok, I tried a different computer, and it now goes very smoothly, including reading the factory ecm. That is only on the truck that worked previously, I have not tried the other one yet. However, when I try to flash even the stock program, I get the message "error, The currently loaded calibration contains one or more incorrect segment checksums. EFILIVE cannot guarantee the integrity of the file and will not allow this calibration to be reflashed into a ECM. Also, when I bring up the flash screen, and click "check status" it attempts 10 times, and displays an error message saying that status is unknown.
    I did check the firmware, and for firmware i have version 2.07.11, and bootblock version 2.07.02
  10. #20
    Do you mean you are attempting to flash it using V7.5? That won't work, you must use V8 to flash a Cummins.
    Can you please send the file that shows the checksum errors to me at paul@efilive.com (so far, of all the files I've received today none of them have shown "bad checksums" so I probably don't have it)
  1. New to EFI, and having Laptop issues
    By millerman04 in forum General
    Last Post: August 29th, 2010, 04:49 PM
  2. lc-1 serial to efi-live issues
    By Jakes4321 in forum General
    Last Post: January 25th, 2010, 11:15 AM
  3. Efi live class at efi university
    By Robbie The Wrench in forum General (Petrol, Gas, Ethanol)
    Last Post: September 1st, 2008, 02:25 PM
  4. New to EFI Live
    By Whitetail Addict in forum Lounge
    Last Post: August 25th, 2008, 06:15 AM
  5. New to EFI Live and RR
    By wickedred in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 3rd, 2007, 04:28 AM
