Results 1 to 10 of 13
Thread: cannot upgrade
    Lifetime Member anarchydiesel's Avatar
    Jun 2011
    Default cannot upgrade
    I just recieved my upgrade code to cummins and have entered all the info in the email, but when I press upgrade it says that it was not upgraded and to check my upgrade codes. Any ideas?
    Oct 2004
    Have you updated your V7 and V8 software and device firmware with the releases posted last night?
    Andrew
    EFILive Crew
    Jun 2011
    I have got the updates installed and got the upgrade done, and have read a base file from a truck. I have tried to open it in v7.5 but it says unrecognized pcm.
    Oct 2004
    Send the file through to me (support@efilive.com). We got a bunch of files through the beta cycle and from users reading their trucks so we could have as many cals as possible supported. It may just be we haven't seen your OS before and need to create a map for it.
    Andrew
    EFILive Crew
    Jun 2011
    just sent it, thanks for the quick help guys.
    Oct 2004
    Got it and it opens fine in the release software from yesterday. Can you please ensure you are running the latest version from our website HERE (and that your FlashScan V2 firmware is updated).
    Andrew
    EFILive Crew
    Jun 2011
    I am updating again will report back with what it does.
    Oct 2004
    If you're running the versions from the website it should be exactly the same as what I'm getting (I have the same release installed locally). But, do let us know if it's not loading for some reason :/
    Andrew
    EFILive Crew
    Jun 2011
    It is working and I am getting blown away by some of the timing numbers I am seeing in a "box" tuner. It is a wonder this truck has not blown up already
    Jun 2011
    Got the tune modified and went to reprogram the truck, but it says it cannot program the ecm in pass through mode. How do I change this setting?
  1. Upgrade OS.....Nothing....
    By Behold in forum General (Petrol, Gas, Ethanol)
    Last Post: May 17th, 2011, 03:30 AM
  2. Upgrade E-38 OS?
    By Bruce Melton in forum E37, E38 & E67 PFI ECM's
    Last Post: June 16th, 2008, 09:45 AM
  3. OS upgrade
    By Naf in forum Gen III V8 Specific
    Last Post: May 19th, 2008, 08:26 PM
  4. upgrade OS??
    By ws6togo in forum Custom Operating Systems
    Last Post: January 10th, 2006, 07:10 PM
  5. No ETC after upgrade
    By curtbriggs in forum General (Petrol, Gas, Ethanol)
    Last Post: October 14th, 2005, 08:35 AM
