Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
Thread: need help with v2 not read pid list
  1. #21
    Quote Originally Posted by restless@westnet.com.au View Post
    ok paul i will keep a look out for the release next week
    can you tell me IF the new ver will read witch GEAR in the latest e3 hsv M6 car with which HAS gear read out on the center screen( HSV of course )
    i know the A6 cars do
    thanks bob
    No. It is probable that the data required to display current gear for a manual gear box is broadcast on the CAN bus by the ECM.
    EFILive does not read the broadcast data while data logging.
  2. #22
    when was it released
    June 24, 2011, here:
    http://www.efilive.com/index.php?opt...=48&Itemid=133
    However, I recommend updating the software using:
    Start->All Programs->EFILive->V7.5->Tools->Check for New Update
    and
    Start->All Programs->EFILive->V8->Tools->Check for New Update
  3. #23
    Senior Member restless@westnet.com.au's Avatar
    Aug 2008
    ok will try it to morrow
    thanks
  4. #24
    Aug 2008
    all works fine now
    do you think the pid TRNR (manuel tranmision states) will work soon
    cheers
  5. #25
    all works fine now
    cheers
    What is wrong with the PID?
    Sorry if its already been explained, I may have simply forgotten.
  6. #26
    Aug 2008
    you said a while ago it was not surported (unknown )
    so i havent tryed it again
    all so could you tell me were to put a trace file to read it
    i have got it on the v2 and in explorer( bottom of the page )but witch part of efilive do you past it in to
    to beable to read it
    thanks
  7. #27
    See images, one is for V7.5 the other is for V8.
ID:	11297   Click image for larger version.
  8. #28
    Aug 2008
    ok ill give it a go cheers
  9. #29
    Aug 2008
    i have up dated every thing v8/v7.5/and the firmware /boot block to day
    now i find that the E38 pid ( gear ) for the a6 just shows a 1 in neutral or unknown
    all so says says unknown when its in gear ? on the v2 screen
    BUT when you log it
    it show which gear OK on play back on the PC screen in scan tool
    all the other 34 pids show on the v2 screen OK
    any ideas
    cheers
  10. #30
    Yes, I find the same thing... on V2 the encoded pids (e.g. TRNR, GEAR, TCCMDE, TSTATExx, STATExx) show value Unknown on V2 and show correct value in the V7 scantool.
  1. Need a PID list please , Blown Silverado
    By TIM Z in forum General
    Last Post: March 14th, 2011, 11:06 PM
  2. AutoCal Read List
    By L31Sleeper in forum AutoCal
    Last Post: February 22nd, 2011, 09:01 PM
  3. GM.E35DSP5_DMA not in my list of PID's
    By foxracingfreak in forum Diesel
    Last Post: September 11th, 2010, 04:44 AM
  4. how to get my pid list to v2?
    By 2004gmc in forum Lounge
    Last Post: May 30th, 2009, 10:52 AM
  5. 98 4l60e PID list
    By 996pilot in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 18th, 2007, 03:53 PM
