At idle before the TB was ported the IACs were around 109 in closed loop, now after the TB was ported the IACs are maxed out at 310, When the car is first started up and is in closed loop for a min the IACs go down to 160s and then start raising up until it reaches 310 again.
My car will not start good now when cold but a have to feather the throttle a little to keep it running for a few bit, and it gets better as it starts to warm up, and by the time it is in closed loop it is fine.
Was my TB damaged when it was ported, or do I just need to lean it out in the Main VE table some more?
