Results 1 to 6 of 6
Thread: Warning: Full flashing for CMB controllers is not supported??????
    Jun 2011
    Default Warning: Full flashing for CMB controllers is not supported??????
    I am lost on this one, have checked all of the versions and hardware and all is good and up to date, so what the heck is causing this? I had no problem scanning my truck and modifying the file but when I select license in V8 for full flash it gives me this error every time. Help?
    That message is controlled by the configuration data files in the folder: C:\Program Files\EFILive\V8\Identify
    We are getting a few reports of the V8 installation not overwriting older configuration files with the new configuration.
    Why that happens I don't know we are still investigating.
    In the meantime try deleting the entire V8 install folder C:\Program Files\EFILive\V8 and then re-install the V8 software.
    That will ensure that the latest of all the files are installed.
    Jun 2011
    Awesome, I deleted the v8 folder and then re installed it and all is good now. Thanks very much.
    Jul 2011
    I am having the same issue. I deleted the v8 file and re downloaded, but I am stilling getting this message.
    Quote Originally Posted by 97singlecab View Post
    Are you trying the "full-flash" option? Only the full-flash option is supported for Cummins, you can't use Cal-only flash.
    Jul 2011
    This was the issue. Thanks
  1. Full flashing
    By killerbee in forum Allison 5 & 6 Speed
    Last Post: February 14th, 2011, 12:31 PM
  2. Problems with flashing already licenced controllers
    By Biodiesel66 in forum FlashScan V2 BB Logging
    Last Post: September 23rd, 2008, 01:27 PM
  3. Full flashing
    By Sparky8370 in forum FlashScan V2
    Last Post: September 23rd, 2008, 10:12 AM
  4. Brand new not yet supported controllers
    By Boost in forum General (Petrol, Gas, Ethanol)
    Last Post: September 21st, 2008, 12:14 AM
