Ive done a search and seems that maybe my situation may be different. At 16lbs and 12 degrees of full timing and full throttle only, will not set codes nor limp mode, but when at 18 degrees on race fuel and same boost full throttle, it triggers codes and limp mode. I have etc throttle rate set at 99.998% and symptom was there before NW 102mm and after. I have C0801 set to max and C0301 set to 15000. Recently made some other adjustments but have not loaded to pcm to test. Trims and afr are great. Any ideas would be greatly appreciated.
