Results 1 to 10 of 19
Thread: Public Release Update June 06, 2011
    Default Public Release Update June 06, 2011
    The EFILive V7.5 and V8 software is available for download.
    This release includes the 5.9 Cummins Scanning and Tuning support.
    Read more about the Cummins features here:
    http://forum.efilive.com/showthread....Public-Release
    Download here:
    http://www.efilive.com/index.php?opt...=48&Itemid=133
    Auto Update:
    The Auto Update option will be activated on Monday June 13 US time. Until then you need to download and install the software manually.
    Once the Auto Update option is activated your system will see it as a new update and download and install it, regardless of whether you have downloaded and installed this release manually or not.
    Known Issues:
    Issue #1
    Some PC's/laptops will freeze when attempting to start the V7.5 Tuning Tool software while FlashScan and/or AutoCal is connected. The problem appears to be an incompatibility between the newest USB drivers and some customer's PC/laptop configurations.
    Please revert back to the older USB drivers. To do that, download the attached zip file, unzip it and run the EFILive_USBManager.exe program. To install the older USB drivers, click on the [Install USB V2.02.04] button.
    Issue #2
    There is a bug in the latest V8 software that prevents the BBX [Program] button from updating the *.obj and *.bix files from being correctly identified as needing to be updated. That means after the user has clicked on the [Program] button the *.obj and *.bix files will not have been updated to the latest version.
    That will usually result in error $050B "Script file not supported by current firmware version".
    The workaround is to have the user to select the "Program All Required Data" from the [Program] button's drop down list.
    Reporting Issues:
    If you discover any serious problems/faults, please create a support case here:
    http://support.efilive.com/
    If you discover simple/trivial issues, please make a note of them in this thread.
    What's new in this update:
    V7.5.7 Build 165 (June 08, 2011)
    • Fixed calculated PIDs expression compiler/evaluator not compiling or evaluating the iff() function correctly.
    • Command line switch "/l" now logs expression parser output (algebraic form) and compiler output (post fix form) to aid expression verification.
    • Installer now automatically updates the cal_summary.txt file with the latest Cummins calibration summary options.
    • Installer now forces overwriting of all non-user modifiable installation files.
    • Added new Cummins OS 11501001
    • Added VATS (vehicle anti-theft) disable for Cummins controllers.
    • Fixed "Access Violation" error when more than 128 BBx config files were selected to be programmed into FlashScan or AutoCal.
    • Fixed *.cax files not being loaded by the V7.5 tune software.
    V8.2.1 Build 156 (June 08, 2011)
    • All *.htx trace files now log the currently installed USB driver and library versions.
    • EFILive Control Panel now displays the USB driver and library version numbers in the "About" screen.
    • Added option to automatically delete *.htx trace files older than a user defined number of days.
    • Disabled buttons and menus in BBx setup window while programming configuration files to FlashScan/AutoCal.
    FlashScan/AutoCal Firmware V2.07.12 (Jun 06, 2011)
    • Added Cummins OS compatibility matrix to pre-flash validation checks.
    Dec 2006
    Nice update , Fixed a few problems I was working around.
    Lifetime Member Chalky's Avatar
    Sep 2003
    System error: Code 1400. Seem to get the error window when closing out Scantool I believe.
    Invalid window handler
    2015 Z06 A8
    Member jay p's Avatar
    Dec 2005
    Quote Originally Posted by Chalky View Post
    I get this same error using the tune tool. It's has never happened when flashing a controller. It's random and there is no single operation that causes it. I tried complete uninstall & reinstall and still get this randomly. The problem computer is a Compaq Presario CQ60 laptop running Win 7x64 Pro with 3 gb of memory. My Mac running XP (32 bit) via boot camp has never done this.
    Jay
    2019 Sierra 6.2l
    2017 2500HD L5P
    2010 2500HD LMM (sold)
    2005 Harley Ultra Classic
    Dec 2006
    What are you doing when this error comes up?
    Sep 2003
    Seem to see it after exiting scantool
    2015 Z06 A8
    Does it happen every time or only sometimes?
    If the cause of the problem can't be found, may I suggest an uninstall/reinstall...
    May 2009
    will more tables be available soon? need to be able to disable brake torque limiting!
    May 2009
    Also pedal position to desired fuel tables don't seem to be sufficient for controlling throttle response...i am not complaining, but hope I am helping
  1. Public Release June 03, 2011
    Last Post: July 9th, 2011, 07:59 AM
  2. Official Public Release - Mar 20, 2011
    Last Post: April 2nd, 2011, 10:02 AM
  3. January 31st 2011 pre-release (Updated Feb 03, 2011)
    Last Post: February 24th, 2011, 06:14 PM
