Results 1 to 5 of 5
Thread: CAX Files still work?
    Lifetime Member JezzaB's Avatar
    Nov 2006
    Default CAX Files still work?
    Thought I would make another CAX file to do a few things I want and I loaded some 01290003.cax files and 01290003 tunes to get back into the 'groove' and nothing shows up. They used to work (been a while since ive done one though). I even tried some old ones with matches stock OS's and still nothing.
    Im putting them in the \Program Files\EFILive\V7.5\Calibration folder. Tried with cable plugged in, not plugged in, Admin rights etc and I just cant get them to work anymore. Currently running V7.5.7 Build 164
    Got me stumped
    Jez
    May 2008
    Do you have the latest version?
    Build 165 (Jun 03, 2011)
    Fixed calculated PIDs expression compiler/evaluator not compiling or evaluating the iff() function correctly.
    Command line switch "/l" now logs expression parser output (algebraic form) and compiler output (post fix form) to aid expression verification.
    Installer now automatically updates the cal_summary.txt file with the latest Cummins calibration summary options.
    Installer now forces overwriting of all non-user modifiable installation files.
    Added new Cummins OS 11501001
    Added VATS (vehicle anti-theft) disable for Cummins controllers.
    Fixed "Access Violation" error when more than 128 BBx config files were selected to be programmed into FlashScan or AutoCal.
    Fixed *.cax files not being loaded by the V7.5 tune software.
    E85 is NOT flex fuel.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
    The June 3rd version has a bug in it regarding .cax files, use the latest June 6/8th V7.5.7 b165 and V8.1.2 b156 and it should work.
    One of the bug fixes:
    "Fixed *.cax files not being loaded by the V7.5 tune software."
    Check it out: June 6th Update
    Nov 2006
    Thanks guys. All fixed with updating. I was 1 build behind
    Member CC&M's Avatar
    Dec 2008
    I just updated mine to 7.5.7 build 165 to get my .cax files going again, but it did not work. What did I miss?
  1. Hmm, here are some other cax files...
    By ringram in forum CAX Files
    Last Post: December 9th, 2011, 11:28 AM
  2. CAX Files.
    By MICK in forum CAX Files
    Last Post: August 28th, 2010, 12:29 PM
  3. CAX files and pseudo lean cruise...
    By harascho in forum CAX Files
    Last Post: November 27th, 2009, 10:48 AM
  4. Getting the LT1 files to work.
    By turbo_bu in forum EFILive V4
    Last Post: July 14th, 2009, 11:53 AM
  5. Merging cax files
    By joecar in forum CAX Files
    Last Post: September 28th, 2008, 08:01 AM
