Results 1 to 8 of 8
Thread: ecm errors out
    Jun 2011
    Default ecm errors out
    Installing efi live in a friend's truck and read his current file and saved it in v8. Not knowing better tried to flash his truck back in v8 and it just kept going and going . I talked to Brayden at Fleece and starting getting somewhere and then tried full flash in v7.5 and kept erroring out. It says ECM is in unknown state. I have tuned alot of dmaxes and had same problem before. I took off the batteries and pulled almost all the fuses and keep getting the same thing. this is what I get:
    18:03:12.750: Autodetect interface ...
    18:03:14.890: Interface not detected
    18:03:16.234: Scanning for EFILive FlashScan V2 HAPI
    18:03:16.250: Autodetect interface ...
    18:03:16.515: Interface firmware version: 2.7.12
    18:03:16.531: Connection to [FSV2] interface is OK
    18:03:16.750: USB driver version: 2.8.20
    18:03:16.750: USB library version: 3.2.4
    18:03:16.765: Interface firmware model: FSV2
    18:03:16.796: Interface firmware model: FSV2
    18:03:16.812: Interface firmware version: 2.7.12
    18:03:16.843: Interface firmware date: Jun 06, 2011
    18:03:16.859: FlashScan serial number: 003870080398
    18:03:16.890: FlashScan license number: 003870080398
    18:03:16.906: Disconnecting ...
    18:03:17.593: CAN-VPW Bridge Deactivated
    18:03:17.609: Disconnected
    18:03:18.406: Scanning for EFILive FlashScan V2 USB
    18:03:18.421: Autodetect interface ...
    18:03:20.578: Interface not detected
    18:03:21.500: Scanning for EFILive FlashScan V2 HAPI
    18:03:21.515: Autodetect interface ...
    18:03:21.796: Interface firmware version: 2.7.12
    18:03:21.812: Connection to [FSV2] interface is OK
    18:03:21.828: CAN-VPW Bridge Activated
    18:03:21.906: Current protocol set to: "ISO 15765 CAN"
    18:03:21.921: Autodetect ECM...
    18:03:21.953: Connection to ECM is OK
    18:03:21.984: Current protocol: "ISO 15765 CAN"
    18:03:22.203: USB driver version: 2.8.20
    18:03:22.218: USB library version: 3.2.4
    18:03:22.234: Interface firmware model: FSV2
    18:03:22.265: Interface firmware model: FSV2
    18:03:22.281: Interface firmware version: 2.7.12
    18:03:22.296: Interface firmware date: Jun 06, 2011
    18:03:22.328: FlashScan serial number: 003870080398
    18:03:22.343: FlashScan license number: 003870080398
    18:03:23.656: Getting status...
    18:03:31.734: Getting status, attempt 2 of 10...
    18:03:33.765: Getting status, attempt 3 of 10...
    18:03:35.796: Getting status, attempt 4 of 10...
    18:03:37.843: Getting status, attempt 5 of 10...
    18:03:39.890: Getting status, attempt 6 of 10...
    18:03:41.921: Getting status, attempt 7 of 10...
    18:03:43.953: Getting status, attempt 8 of 10...
    18:03:46.000: Getting status, attempt 9 of 10...
    18:03:48.031: Getting status, attempt 10 of 10...
    18:03:50.062: Status: Unknown.
    18:03:51.062: Bootloader version: P_59_v1.9F (09FC-EBB2)
    18:03:51.062: Preparing ECM for reflash...
    18:03:53.109: Autodetect interface ...
    18:03:53.390: Interface firmware version: 2.7.12
    18:03:53.390: Connection to [FSV2] interface is OK
    18:03:53.406: Autodetect PCM...
    18:03:55.437: PCM not detected.
    18:03:56.453: ECM may not be secured - did not reply to seed request
    18:03:56.468: Initializing ECM...
    18:03:56.468: Initializing ECM, step 1 of 4
    18:03:56.468: Initializing ECM, step 2 of 4
    18:03:56.468: Initializing ECM, step 3 of 4
    18:03:56.468: Initializing ECM, step 4 of 4
    18:04:01.484: No response from ECM. Retry 1...
    18:04:03.640: Autodetect interface ...
    18:04:03.906: Interface firmware version: 2.7.12
    18:04:03.906: Connection to [FSV2] interface is OK
    18:04:03.921: Autodetect PCM...
    18:04:05.953: PCM not detected.
    18:04:06.968: ECM may not be secured - did not reply to seed request
    18:04:06.984: Initializing ECM...
    18:04:06.984: Initializing ECM, step 1 of 4
    18:04:06.984: Initializing ECM, step 2 of 4
    18:04:07.000: Initializing ECM, step 3 of 4
    18:04:07.000: Initializing ECM, step 4 of 4
    18:04:12.031: No response from ECM. Retry 2...
    18:04:14.375: ECM is in an unknown state.
    18:04:16.796: Disconnecting ...
    18:04:17.484: CAN-VPW Bridge Deactivated
    18:04:17.484: Disconnected
    18:04:18.046: Data transfer was interrupted.
    18:04:20.421: Done!
    Now I am stuck and don't know what to do. Need help fast because his truck is dead right now.
    thanks
    Firstly, you can't flash a Cummins using V7.5, it is not supported. Only V8 can flash a Cummins.
    Just for your info, the line:
    Shows that V7.5 is attempting to reflash an LS1, which is the default controller if the ECM type of the currently loaded file cannot be determined by the V7.5 software.
    Anyway, back to V8 flashing the Cummins. When you attempted to flash the Cummins and it just went on for ever, a trace file would have been saved by the V8 software.
    Can you please locate that trace file? It will be in the folder called: \My Documents\EFILive\V8\Trace and it will be named something like this: CMB_F_20110603_155239.htx
    Where the two groups of numbers are the date (YYYYMMDD) and the time (HHMMSS) that the flash was attempted.
    Please send that file (or all files in the trace folder if there aren't too many) to me at paul@efilive.com
    Is it possible that your truck had a hand-held tune in it prior to you reading it out with EFILive?
    If so that is most likely the cause of the problem. Some hand held tuners do not return the controller to stock even when they are commanded to return to stock.
    Which means the tune that you read out of the (no longer stock) controller cannot be flashed using EFILive.
    You must flash in a stock tune using EFILive to return it to 100% stock. You can obtain stock tunes here:
    http://www.tunefiledepot.com/index.p...Type=D&Stock=Y
    If that is not the case, i.e. there has been no hand-held tune in your truck (that you know of), please send me the file that you read from your truck.
    That way we can see if the tune file has a problem that is preventing from being flashed.
    Jun 2011
    how do i change the os and vin to match what my friend's truck had in it? I do use v8 to program with right? Brayden told me v7.5
    Download a matching file from the web site I gave and flash it in using V8.
    Then using V7.5 Scan Tool, change the VIN to match your truck's VIN so you can start it.
    In V7.5 Scan Tool use the menu option: Bidirectional -> Change VIN...
    Jun 2011
    worked and thanks a million.....great customer service and fast
    Jun 2011
    i guess i didn't change the vin right and the bidirectional isn't highlighted to let me do that
    You need to click on the "Connect" button (round green button at top left) and select the CMB controller.
    Once connected, you can change the VIN.
  1. Scan and errors
    By eboggs_jkvl in forum General
    Last Post: August 18th, 2007, 10:52 AM
  2. Table errors
    By Biodiesel66 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 26th, 2006, 08:32 AM
