Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Having trouble connecting V4 to vehicle
    Nov 2007
    Also, I normally disable the chatter option in the def when I have the PCM on the bench (no BCM) or it wont connect.
    New Member RBR's Avatar
    Jun 2011
    Thanks for the help Fellas.
    RBR, Toyota Landcruser, L67
    Jun 2011
    I went for a test run and now I think that the ignition timing scale may be incorrect, as I am getting 30* at idle and when I go to WOT the ignition advance goes off the scale but the engine seems to be running fine.
    I will try and check the timing against a timing light.
    Does anyone know what the timing is on a VT V6 supercharged commodore.
  1. RR not connecting..need help
    By superspeed in forum RoadRunner Real-Time PCM Emulator
    Last Post: January 29th, 2009, 12:50 PM
  2. New help connecting to RR
    By 99ss in forum RoadRunner Real-Time PCM Emulator
    Last Post: August 25th, 2007, 11:57 AM
  3. LM-1 connecting to V1
    By turbo lcc in forum General (Petrol, Gas, Ethanol)
    Last Post: January 27th, 2007, 11:06 AM
  4. Scan tool not connecting to vehicle?
    By kbracing96 in forum General (Petrol, Gas, Ethanol)
    Last Post: October 25th, 2006, 05:09 PM
  5. Trouble connecting
    By ahall1 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 26th, 2005, 11:30 AM
