Thread: EFI Problem, stumped
    Senior Member DmaxHawk's Avatar
    Apr 2008
    Default EFI Problem, stumped
    Im working on putting a dsp 5 on a 07.5 lmm and have no idea what's going on with it. I installed the switch with no problems. Now when I try to flash the dsp tune the truck accepts the tune fine. When I try to drive it on the other hand, that's when it starts acting strange. I step on the throttle, rpms increase and then start jumping around like it had a rev limited or something. I checked all the tables and they look good. If I load a stock tune, it works fine...anyone have any ideas?
    07 El Bee Zee
    Little faster than stock...
    Jan 2008
    So what happens if you take the stock file and upgrade it to DSP5 and flash that? what happens? I would be willing to be that there is either a pin loos in the ECM connector or there is a table or set of table in the base tune that aren't working correctly.
    Apr 2008
    Thats what I did. The base tune works fine as a single tune, when I upgrade it to a DSP, thats when it starts jumping around. And it does it on every tune, even the stock base tune that worked fine...
    07 El Bee Zee
    post your tune and your log of the behavior, if you want help.
    Custom Tuning Services
    Apr 2008
    Here is the tune, I will post the log when I get it.
    07 El Bee Zee
    I think you will find the problem in your EGR desired flow tables.
    The log will be helpful, if you log all the EGR pids.
  1. Can EFI log data regarding my shifting problem?
    By 5akman in forum Allison 5 & 6 Speed
    Last Post: June 13th, 2011, 02:18 AM
  2. Replies: 3
    Last Post: October 29th, 2009, 09:09 AM
  3. EFI Live V2/USB Comunication Problem
    By castewart in forum Duramax LB7
    Last Post: May 21st, 2009, 09:55 AM
  4. Efi Live Tuning Problem,, Need Help
    By Boll Curlee in forum General (Petrol, Gas, Ethanol)
    Last Post: November 18th, 2006, 07:43 AM
  5. Problem with linkups with V5 & V6 EFI
    By jbrunton in forum General (Petrol, Gas, Ethanol)
    Last Post: May 3rd, 2006, 01:19 AM
