Results 1 to 5 of 5
Thread: Wheel speed vs Engine RPM
    Dec 2008
    Default Wheel speed vs Engine RPM
    I saw someone graph of Wheel speed vs Engine RPM, I think it came from HP tuners, do we have a similiar map? I'm guessing they are grabbing the ABS wheel speed sensors?
    Ed
    Hi Ed,
    RPM and MPH are related by RPM / MPH = 336 * GR / TD where GR = overall gear ratio and TD = tire diameter inches.
    you can rearrange to get MPH = RPM / 336 / GR * TD and make a calc pid for it.
    Or if you want wheel speed in rpm, then engine / wheel = GR = axle * trans
    rearranging: wheel = engine / GR = engine / (axle * trans)
    If you have an A4, you can make a calc pid (using your axle ratio instead of 3.23): WHEEL = {SAE.RPM} / (3.23 * {GM.BOXRATIO})
    There's nothing in the HPT scantool that EFILive scantool can't do...
    Dec 2008
    No It looked like he plotted front wheel speed, rear wheel speed and engine rpm. He was using it to show traction leaving the hole. It showed wheel spin vs front and engine rpm coming down to match rear wheel speed.
    I saw it on LS1 Tech here it is.
    http://www.ls1tech.com/forums/drag-r...lip-graph.html
    Jul 2008
    That looks like a simple Excel program..
    He's logging the pid GM.WHLSPD which relies on comms from the ABS/EBCM controller.
  1. Slow engine rpm drop after rew
    By Ram Air IV in forum General (Petrol, Gas, Ethanol)
    Last Post: April 9th, 2011, 06:54 AM
  2. speed/RPM limit cancel!!
    By A.O.A in forum General (Petrol, Gas, Ethanol)
    Last Post: May 27th, 2009, 05:44 AM
  3. Engine Zone rpm ranges
    By Redline Motorsports in forum E37, E38 & E67 PFI ECM's
    Last Post: July 29th, 2007, 02:03 PM
  4. speed vs, rpm?
    By ytry in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 18th, 2006, 01:34 AM
  5. How many RPM is safe for a genIII truck engine?
    By Wasted Income in forum General (Petrol, Gas, Ethanol)
    Last Post: February 18th, 2006, 04:52 PM
