Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: 2001 '0411 reflash OS to '02 12212156 now wont start-
  1. #21
    Member overS10ded's Avatar
    Mar 2009
    That worked!!! It's running again! Looks like I have a few DTC codes to track down now...after lunch! Thanks for your help!
    Good times!
    Bruce
  2. #22
    May 2010
    Good deal.
    1997 S10, 06 trailblazer SS LS2 swap, 4L70E trans, 76mm turbo. Factory ZQ8 suspension. 3.08, G80 w/a zexel. With a 0411 swap.
  3. #23
    Aug 2010
    Nice to hear you got it running - nothing worse than a "no start" event. You will need to confirm the knock sensor(s) you are using - tune is currently configured for Flat Response (LS2 style) knock sensors - found in B1402. I believe the type of knock sensor changed at some point on the 4.3 L V6 - not sure when - you may have the Resonant (LS1 style) knock sensor.
    Regards,
    Taz
  4. #24
    Mar 2009
    I had to change knock sensors to the flat response type when I installed the '0411 a few years back. If I have a problem with weeding out the DTC's I'll be back!
    Thanks again!
    Good times!
    Bruce
  5. #25
    May 2010
    Just to update this thread and confirm that the tune file in post 14 is not a true stock manual trans file. Some of the airflow tables and quite a few others are not close to being consitant with an original factory man tune for a S10. Enough differences to cause driveability issues. Although it can be made to work with the correct changes just not 100% correct.
  6. #26
    May 2010
    Also forgot to say I will post up the 2002 s10 man. tune as soon as I confirm the ecm has never been flashed by this trucks owner.As I have already read it. But 100% sure it is a man tun as I am looking at the truck. These 4.3 s10's are hard to come by in a stick.
  7. #27
    Mar 2009
    Thanks "slows10"! I look forward to compareing your "stock" tune with mine to see if I missed anything. I do have some issues that I need to iron out the next time I'm back in the states. I have the blower on and managed 21mpg on a 500 mile trip, also making 4#'s of boost with the current pulley which I have a 3.75" replacement pulley to replace the 4.1". Removed and cleaned the injectors which helped but still need a 2 bar map to make things work w/cos5. Things pulled pretty good for 4#'s but I really didn't take time to do much tuning-other family priorities ya know.
    Good times!
    Bruce
  8. #28
    May 2008
    I uploaded one for a 2002 blazer to holdencrazy. The transmission segment is probably different and things like gearing and fuel tank, but you should be able to look at the airflow tables from that. Otherwise, I think there was a Sonoma or S10 tune up that should work.
    E85 is NOT flex fuel.
    2003 Chevy S10 4.3L LU3 LS1B Auto
    48 LB injectors
    Race Proven Motors 2114 intake
    T70 turbo.
  9. #29
    May 2010
    Quote Originally Posted by nevinsb View Post
    Correct. Since the op has a auto trans he should be able to use the airflow tables. But for someone running a manual trans, this tune is not correct. Thats what I was pointing out. It shouldnt really be labeled a manual trans tune when its not. Just tryin to help others in the future who may need this tune. The airflow tables and others are alot different between a man and automatic.
  10. #30
    May 2008
    Aah, I thought he wanted to use a manual tune for the 700R4 and copy the airflow tables over from an automatic tune.
    48 LB injectors
    T70 turbo.
  1. Sputters wont start
    By chops3131 in forum Duramax LB7
    Last Post: April 22nd, 2009, 05:04 AM
  2. wont cold start
    By dlove in forum Gen III V8 Specific
    Last Post: October 21st, 2008, 01:30 PM
  3. Car wont' start, need some help!
    By Loudmouth LS1 in forum Gen III V8 Specific
    Last Post: June 17th, 2008, 10:08 PM
  4. New RR wont start the car
    By ntae in forum RoadRunner Real-Time PCM Emulator
    Last Post: December 18th, 2007, 08:45 PM
  5. 408 with 90/90 wont start
    Last Post: March 20th, 2007, 11:38 PM
