Results 1 to 3 of 3
Thread: What changes or adjustments are needed for early transmission swaps???
    Jan 2010
    Default What changes or adjustments are needed for early transmission swaps???
    I have'nt been able to find much info on swaps using early transmissions. Specifically what perameters need to be changed if your not using an electronicly controlled transmission??? Do I need to have some type of speed signal from the wheel or driveshaft??? I am not worried about Gauges as this would be for an older car.
    I want to make sure the engine starts, runs, and functions properly with an earlier transmission. Any tips or maybe links to this info???
    Aug 2010
    Hello 1FastBrick,
    If you plan on running a non-computer controlled automatic transmission with a Gen III V8 - then a tune from a manual transmission vehicle is generally used. You need a VSS input to the PCM. This signal can be taken from the transmission, driveshaft, wheel - pretty much anywhere you want - then adjust the tune accordingly.
    Unless you already have a high quality non-computer controlled transmission - from an ease of tuning / driveability / fuel economy perspective I wouldn't recommend using one. A 4L60E or 4L80E (for heavy duty use) are much more user friendly and just about infinitely configurable - including the option of two different shift patterns - one for cruising / daily use, and another for the track / spirited driving.
    Regards,
    Taz
    Jan 2010
    Thanks for the Info Taz. What are most people useing for a sensor and ring to get a VSS signal??? Are there kits availble for this type of conversion
  1. Locking Converter Early?
    By jamesbond2509 in forum Tuning For Economy
    Last Post: January 22nd, 2014, 01:18 PM
  2. Can't find info on trans segment swaps
    By pullincrazy88 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 12th, 2011, 02:19 AM
  3. Replies: 1
    Last Post: March 16th, 2011, 07:59 AM
  4. LS1/LS2 swaps?
    By Cougar281 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 24th, 2007, 03:47 PM
  5. Trans upshift at WOT way too early ?
    By J 98ta in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: October 27th, 2005, 12:46 PM
