Results 1 to 6 of 6
Thread: little advice on gently adjusting TCM tune - I want to help not hurt
    Lifetime Member Boost's Avatar
    Dec 2006
    Default little advice on gently adjusting TCM tune - I want to help not hurt
    So I've been researching several of the threads regarding this and learned a few things none of which encourage me too much to go tweaking the Allison settings. I usually leave the tranny tune alone because I feel that if it's not built, the stock tranny really needs the protection of the defuels and such especially to guard it from the 5-600 hp "bolt-on" tunes I've been working with. I always knew I could make it shift "better", at the expense of reliability and possible catastrophic failure. So I haven't. But the defuels get much more noticeable / bothersome on big power applications so if I can "match" the ECM tune better to make the tranny even more reliable and feel smoother, that is what I'd like to do. So what is the basic theory in "matching" the tune, this is a little different than zeroing out shift times and bumping pressures. Thanks a lot!
    8.7 @ 84 (1/8 mile) bolt-ons
    Dec 2005
    Shift quality has to do with ECM tuning, not TCM tuning. Shift pressure is a mechanical change inside the Allison and not with trans software.
    Don't make the mistake and disable the torque request either, that will wreck a transmission in short order.
    Good Luck
    www.mscservices.net
    Dec 2006
    That's what I suspected, it will be left alone for now. Thank you. The shifts are not bad, just the typical de-fuel in between which is much more noticeable at 500+ horse. Some E.T. I am sure is lost there but I always thought it was worth it and just focus on lauches and power. With a stock tranny I was happy with solid mid 8 second 1/8 miles. It needs to be built for sure not only to "shift quicker" and hold more power, but to be reliable on the long run too. No?
    Dec 2006
    One more thing, if I work towards fine tuning the ECM for smoother shifts, would that be easier on the tranny? Or is a hard defuel very good protection. What areas of the tune are best to start researching about this? Any good threads? Thanks!!
    Jan 2006
    Not sure which TCM you have? If you have a pre-06, then Tony is correct, and there is improvement in the ECM to be had. Excess defuels (IMO) are an annoyance, especially at low loads. It is possible to make these shifts transparent.
    This is not an easy topic to discuss, if centered on refinement and longevity. Except to say that poor refinement, especially in commercial tuners, is simply a lack of any attention to it. You can do much better with a little effort.
    Custom Tuning Services
    Dec 2006
    Sounds good, thanks a lot!
  1. Good N/A Tune but...Going Supercharged I could use advice on a base tune
    By tatasta in forum Forced Induction and Nitrous Oxide (N20)
    Last Post: April 6th, 2011, 09:16 PM
  2. Advice on my transmission tune.
    By ippielb in forum Gen III V8 Specific
    Last Post: October 20th, 2010, 10:53 AM
  3. 2nd Tune after advice...whatcha think?
    By shadyst in forum Gen III V8 Specific
    Last Post: July 29th, 2009, 07:11 AM
  4. Ideas/help adjusting my nitrous tune for NA
    By jermstyle in forum Gen III V8 Specific
    Last Post: December 9th, 2008, 03:52 PM
  5. Need advice on a TT408 tune problem..
    By Redline Motorsports in forum General (Petrol, Gas, Ethanol)
    Last Post: August 7th, 2005, 01:17 PM
