I am working on a Tahoe with a charging system complaint. Everything seems good and solid and it has a new battery, so I just wanted to scan it for history codes before I let it go. To my suprise, when I connected to the OBDII port and the FS, instead of powering up normal, it lit up very dimly and the lights very blinking / flashing rapidly. When I proceeded to connect to the laptop, it powered up normal, and everything worked fine. Except I noticed while logging data, some of the values changed so rapidly that they were difficult to read. What does this mean about the vehicle?
