Results 1 to 10 of 13
Thread: P12 chevy colorado ecm
    Junior Member hondarider552's Avatar
    Apr 2008
    Default P12 chevy colorado ecm
    I read my stock tune file form my 06 colorado 3.5L, saved the tune file on my desktop, but now when I open the tune file, a message comes up saying efi doesnt support this ecm
    Heres a pic of the error I keep getting. I justt updated my V2 and firmware to the newest build (165 as of june '11) and I keep getting the message??? hmmm
    03 single cab work truck LB7- 11.95 @ 113
    06 crew cab lowered Colorado.
    Feb 2006
    Is your efi live software up to date?
    Al
    Apr 2008
    well, I thought I updated the software, how/where can I check?
    I open efilive scan and tune tool, and its version 8.2.1 build 156
    Feb 2006
    Sorry I didn't see your version. Yours should be updated enough. When you read it, did you have an error message then? Maybe do a re-read.
    Al
    Apr 2008
    I'll re-read it tonight, im thinking that was my problem. I never got a error message while reading, took 3 mins or so, just over 1000kb file. I only got the error when I tried to open the tune.
    thanks.
    Make sure your V7.5 software is up to date as well, should be dated June 8th and be 7.5.7 build 165.
    Apr 2008
    Well still no luck. Updated my v2 with newest software and firmware, and re-read my colorado ecm, everything is fine untill I shut the key off and wait for ecm to reboot, and it comes up with the same error message as before... wtf.. :/
    I know the ecm is supported because it will read it, so I dunno whats going on..
    I also found a stock 3.7 liter colorado .tun file on here, I can open that tune up, make changes, save it etc etc, but not mine? How does thatt work out??
    Brian
    Can you Email your tune to support@efilive.com, it may very well be an OS we've not seen before.
    Apr 2008
    Email sent, thank you.
    OS is 12627883
    Apr 2008
    This was the actual thread I found the stock 3.7 2007 file from.. and it works perfectly for me..
    http://forum.efilive.com/showthread....5-screen-shots
  1. Chevy Traverse... E67?... locked ECM? trouble reading
    By ericdrob67 in forum E37, E38 & E67 PFI ECM's
    Last Post: September 17th, 2013, 09:55 AM
  2. Need 05 colorado 2.8L stock tune
    By blazinblue in forum IL6,IL5,IL4 Atlas Engines - P12 PCM
    Last Post: April 22nd, 2010, 05:40 AM
  3. 2008 Chevy Silverado 2500hd ECM?
    By dietz4ibanez in forum FlashScan V2
    Last Post: July 12th, 2009, 01:38 AM
  4. Colorado/Canyon tuning
    By jah81592 in forum General (Petrol, Gas, Ethanol)
    Last Post: April 23rd, 2007, 02:00 AM
  5. EFILive on an 05 Chevy Colorado?
    By Blk02Ls1A4 in forum General
    Last Post: August 29th, 2005, 05:21 PM
