Results 1 to 10 of 10
Thread: rear end change
    Junior Member ws6togo's Avatar
    Mar 2005
    Default rear end change
    I just changed my wimpy 3.23 gears to 3.73 to give the ol LS1 more "power on tap" Does anyone know what settings in EFI scan and tune I need to change? I am guessing the speedo needs to be adjusted but do I need to do any other settings for the change. Oh yeah....I also have a 3000 stall speed TCI converter....should I make any changes there or just let the converter do its thing? Also will be taking off the EGR (going to LS6 intake so won't be needing that crap !!) and will be taking out the AIR also. Does anyone know what settings to disable the AIR. I found the one for EGR.
    Thanks for the help,
    Nov 2003
    To disable Air go here:
    http://www.bowlingss.com/Removing%20...%20Ls1Edit.htm
    Just type the code in the search section.
    I used LS1Edit a year or more ago but the DTC's are the same.
    The gears I think should be under Spedo. See jpg.
    As far as the TC. Did you have a shift kit installed? If not I had to make a few changes to the line presure but I had LS1Edit then and would have to do some looking to see what I changed.
    Bill
    2011 Camaro 2SS/RS L99 RJT
    VMax Ported RJT Throttle Body
    Gorilla Wheel Lock System;
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    I did an update to the www.ls2.com information.
    http://www.ls2.com/forums/showthread...951#post300951
    Enjoy,
    Elmer
    2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
    Mar 2005
    Quote Originally Posted by BowlingSS
    It used LS1Edit a year or more ago but the DTC's are the same.
    As far as the TC. Did you have a shift kit installed? If not I had to make a few changes to the line presure are.
    Bill
    Have not made any changed for the TC. I dont have a shift kit installed. Can you give me some guidance to the changes you made in line pressure? Isn't it kinda hard on tranny if line pressure is to high or low?
    '00 Pewter TA WS6 12.6@111 on street tires 1.87 60'
    PERFORMANCE: BG Ram Air, Lid, K&N, MSD 8.5 wires, NGK TR55's, 160*
    SUSPENSION: BMR-STB/SFC/PHR, UMI LCA's
    DRIVETRAIN: rebuilt 4L60E. 3000TCI, Hayden Trans Cooler, Yukon 3.73's, TA girdle
    TUNING: EFILive
    No runs after engine upgrade
    Newest mods:LS6-intake/heads/ported oil pump, 28lb injectors, Comps-918's, Comps 224/230 .581/.592 114 cam, Dynatech LT's, Rollmaster chain.
    Nov 2003
    Quote Originally Posted by ws6togo
    I had to make a few changes to the line presure but I had LS1Edit then and would have to do some looking to see what I changed. You do not want it tooo high. If you want I can send you my tune and then you could just do a compare for the changes.
    Bill
    Mar 2005
    Bill
    That would be GREAT....Thanks !!
    TUNING: EFILive
    Nov 2003
    I need your E-Mail address...
    Bill
    Mar 2005
    TUNING: EFILive
    Nov 2003
    Talking
    Tune sent. Hope it helps. Every tune is different so what works for me might not work the way you like it. Every car is a little different. Just keep that in mine when copying parts of any tune.
    Bill
    Mar 2005
    Default Thanks
    Thanks again for the tun file BowlingSS
    TUNING: EFILive
  1. Deleting Rear 02's
    By Gordy M in forum General (Petrol, Gas, Ethanol)
    Last Post: December 30th, 2009, 07:54 AM
  2. C6 Z06 Rear End in a C5 with a 4L60E
    By JR-CRUZN-C5 in forum FlashScan V2
    Last Post: April 16th, 2008, 08:25 AM
  3. rear 02 sensors
    By aaronr in forum Gen III V8 Specific
    Last Post: December 17th, 2007, 01:38 PM
  4. rear axle max torque and rear prop shaft numbers
    By mtnman in forum General (Petrol, Gas, Ethanol)
    Last Post: June 17th, 2006, 04:10 PM
  5. Rear O2 delete and EGR
    By 87gmc in forum General (Petrol, Gas, Ethanol)
    Last Post: April 4th, 2005, 04:13 AM
