Results 1 to 3 of 3
Thread: Gen III ETC
    Junior Member MaxPF's Avatar
    Jul 2010
    Default Gen III ETC
    I know the Atlas engine has a parameter for electronic throttle max opening rate. Do the Gen III PCMs on engines with ETC have any similar parameters?
    The engine in question is an LM7 5.3L, and the Os is 12592618
    TIA,
    Greg
    Aug 2010
    Hello Greg,
    OS 12592618 is a 2005 LS1-B OS. There are ETC parameters available in EFILive - these are in a "red" folder - and this folder is only visible if your V2 is plugged into your Notebook computer prior to opening the Tune Tool.
    B2702 (ETC Max Position) should already be set to 100% by default in all cells.
    B2307 (ETC Pedal Response - Primary) - values for pedal % and actual TP % become closer the further above 68% TP you progress. This is the table that is primarily used by the PCM.
    B2308 (ETC Pedal Response - Alternate) - this table is used in various driving modes - the pedal % and TB % are vastly different.
    Hope this is the information you were looking for ..........
    Regards,
    Taz
    Jul 2010
    Thanks Taz!
  1. Correct IFR tables for LS3/LS7 injectors in Gen III
    By SweetS10V8 in forum Gen III V8 Specific
    Last Post: August 13th, 2018, 07:27 AM
  2. Full Flash of Gen III 1MB PCM
    By DPS in forum FlashScan V2
    Last Post: April 10th, 2011, 11:06 PM
  3. Gen III supported operating systems
    By 02Z06 in forum Gen III V8 Specific
    Last Post: June 30th, 2010, 07:24 PM
  4. Gen III 5.3 To Gen IV 6.0 (LY6) 2004 Avalanche
    By spacediver in forum Gen III V8 Specific
    Last Post: March 23rd, 2010, 09:41 AM
  5. Logging Timing on Gen III 5.3
    By LBZoom in forum Gen III V8 Specific
    Last Post: November 8th, 2008, 08:06 AM
