Results 1 to 6 of 6
Thread: LMM DSP5 EGR Referencing?
    Aug 2010
    Default LMM DSP5 EGR Referencing?
    I'm trying to get my DSP5 to work in my LMM, and I'm noticing that on the Custom Calibration tables there is only "EGR OFF" tables, so does this mean that with EGR enabled it will reference the base tunes "EGR On" Tables? If so will just setting EGR control to "Disabled" fix this? Thanks for any help.
    Jan 2006
    Good question.
    Custom Tuning Services
    Jun 2011
    I can tell you one thing.. there is definately a problem with a DSP5 LMM tune I've been working on.. even after setting all possible extreme ranges to disable EGR, I have the ECM referencing the EGR OFF Boost table but using the EGR ON Vane position table.. this is a VERY big problem.. DSP5 OS bug perhaps??
    Senior Member DmaxHawk's Avatar
    Apr 2008
    Quote Originally Posted by Black6spdZ View Post
    I've got a LMM which seems to have the same problem. I've tuned 2 other LMMs before the current one with no problems. OS 8594, what OS do you have?
    07 El Bee Zee
    Little faster than stock...
    Jan 2008
    Quote Originally Posted by North Maine View Post
    yes, you are correct. If the EGR is ON, then it will reference the base tune EGR ON tables.
    Jan 2008
    Quote Originally Posted by DmaxHawk View Post
    we've got him straightened out in another thread. Not a DSP OS bug.
  1. LMM DSP5 timing issues
    By dansdieselp in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 26th, 2011, 02:58 PM
  2. Lmm dsp5 issue!
    By cumminsDK in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: September 7th, 2010, 11:47 AM
  3. LMM-dsp5 time delay
    Last Post: June 3rd, 2010, 03:17 PM
  4. Lbz/lmm dsp5
    By Cougar281 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 10th, 2010, 03:16 PM
