Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: my friends 98 ta is shifting way before its calibrated wot shift points
    Jun 2009
    Default my friends 98 ta is shifting way before its calibrated wot shift points
    Hi, recalibrated my friends 98 ta for him and everything is good except for the wot shift points , i left them as is at 6000 for the 1>2 and 5900 for the 2>3 , 5900 for 3>4 but when logging i noticed the the 1>2 shift was very close to 5500 and the 2>3 was very close to 5700, everything seems good as i corrected for a gear change in speedo calculator to input the correct pulses per km and output shaft revolutions and i did a shift point correction also because of the new 3.42 gear , could it have to do with the wot shift speeds even thought they were corrected when i did a shift point correction, i am sure gm wanted these shift points so they set the wot shift points to 6000 and 5900 and then set the wot shift speeds so it would shift at 5500 and 5700 and when i corrected for the 3.42 gears that all stayed the same , so i am thinking i should up my wot shift speeds , the wot shift speeds are way below what they would be at the wot rpm shift points but i noticed that the difference is less for the 2>3 and maybe this is why it is shifting closer to its wot shift rpm, so am i on the right track or is it something else , i will have the car this afternoon , if what i am saying is correct it will be trial and error to fix this to the desired shift points i want by uping the shift speeds at wot , thank you Eric
    Senior Member Chuck L.'s Avatar
    Feb 2006
    Chuck L.
    CODY Motorsports
    Fuel Injector Service
    Madison, GA.
    706-342-3152
    770-265-5144 [C]
    The WOT shifts require both WOT RPM and WOT MPH to be met...
    so, to shift at a specific WOT ROM, set the WOT MPH a little lower, and then by trial/error adjust the WOT RPM until the actual shift RPM is achieved.
    Jun 2009
    Thanks Chuck , nice thread lots of information , nice work Joe, so i was on the right track about the wot shift speeds , Joe when you say set the MPH a little lower do you mean the MPH at my wot shift rpm , so i caculate what my MPH would be at lets say 6000 which is my desired wot shift rpm and i set it back a bit , really that is trial an error , well looks like i wont be doing this tonight , does this also go for my 2000 silverado truck or is it specific to 97,98 pcms, thanks Joe
    Set one of them down a little (so it is met first), and use the other to set the actual shift point (so it is set second).
    Jun 2009
    Ok i will try that Joe , oh have another question concerning the same log , i also logged the pid feul system a and b and i noticed it is always in closed loop , can this be under wot , it has to go into pe at wot , am i just not getting the info because of a pid mix match , i believe i did not build the log file while connected to his ta , i just used the log file that i use on my truck , is this where my problem is , but i think i remember that when i connected to his ta before logging it did validate the pids, in the log i can see the commander afr which looks normal at about 12.5 at wot and my o2s did not go below .903v at wot and that is close to 13.2 afr , i dont want to connect my wide bands , i just want to make sure it is getting into open loop , thanks Joe what would we do without you, Eric
    Not just me, but all the contributors on this forum, they have given their time and experience...
    Look at his tune file, what does B3616 say, this is the condition for going into PE (it should also go OL).
    Jun 2009
    Yes i know i am a bit confused about the open and closed loop , i know it should be in open loop until warmed up and closed loop relies on nb sensors for feul ajustment , my truck goes into open loop because it is supercharged , i have done no ajustments that concern feuling as you can see , feuling is all new to me but it will not be for long , so it is normal that my friends 98 ta stays in closed loop because it is set up that way in the tune and my truck because of my supercharger will go into open loop at wot and will not rely on the nb sensors for fueling but rather PE , does all this make sence or am i way off track , i imagine when supercharged the mixture is way to rich at wot to have any accuracy using nb o2s, i have seen as low as 11.7 on my trucks widebands but commanded was a bit lower so when i do become more in tune about all this i will fix that, thanks Joe hope you can clear all this up a bit for me , Eric
    Jun 2009
    Thanks Joe , you got back to me as i was sending you my last reply , so what makes sence about all i said , i will check out B3616 and get right back , Eric
    If the AFR is more than a few points off from stoichiometric, then the NBO2's can't trim so it goes OL.
  1. 4L60E shift points
    By maudyZ28 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: April 28th, 2010, 02:37 PM
  2. Shifting points of camaro 2010
    By odd boy in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: April 22nd, 2010, 12:06 PM
  3. Little help with changing shift points
    By Tarkstoys in forum Allison 5 & 6 Speed
    Last Post: June 29th, 2009, 06:54 AM
  4. shift points
    By rock04max in forum General
    Last Post: December 1st, 2008, 01:09 PM
  5. TCM shift points
    By lakingslayer in forum General (Diesel)
    Last Post: March 28th, 2007, 11:09 AM
