Results 1 to 10 of 10
Thread: Reading other programmers files??
    Default Reading other programmers files??
    I currently have a aftermarket programmer in my Duramax. If that program is already flashed into the PCM, then why shouldn't I be able to read the PCM as if its stock? Being new to the diesel tuning I would like to see the differences between stock and what needs to be changed. The stuff looks Greek to me!
    Also should the XM radio and radio fuses be removed prior to PCM readings?
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Senior Member Wasted Income's Avatar
    Dec 2005
    Yes, you can read the Diablosport tune, and yes, I'd pull the radio fuses...
    2005 Silverado Duramax LLY - EFI Live Tuned
    1969 Chevrolet C-10 Pickup - Turbocharged 5.3L/4L80E - EFI Live Tuned
    1975 Avenger Jet Boat - 6.0L/Berkley pump - EFI Live tune in progress
    Lifetime Member Max Power's Avatar
    Nov 2005
    No need to pull fuses unless you have aftermarket accessories that communicate on the data such as an aftermarket xm adapter. OEM is fine. You won't hurt anything on a read if it does error. It's nice to not have to pull the fuses because then you don't lose your time etc.
    You can read tunes such as that but keep in mind they are copyrighted so it is likely illegal to do so.
    09 LMM Duramax
    My dealer ended up forgeting to order my XM so I installed a factory GM unit after I got the truck. I assume this system does not draw off the same data line.
    I think I am going to reflash to stock and save the file. Then I'll load up the different tunes and save each. This should add insight as to what parameters are relevant. My truck is currently on the 60 hp tune and the numbers it makes are in my sig.
    Looks like I should just order a Level 5 tranny right now!
    1-954-703-5560
    Nov 2005
    If it is the GM XM you will be fine. We are having problems with the Soudgate, PIE, PAC units.
    09 LMM Duramax
    Dec 2005
    Quote Originally Posted by Max Power
    Well if HE OWNS the Predator, then there should not be a problem backing up and modifying the tunes for his OWN use.
    Thoughts?
    I adjusted my post to keep the air clear. Both have good points. Problem solved.
    Howard
    1-954-703-5560
    Nov 2005
    Quote Originally Posted by Wasted Income
    Thoughts?
    Maybe so, but why push the issue? We all know it can be done. If you choose to do it that is fine with me, let's not discuss it in public for the sake of the owners of the site. That's all I'm saying
    09 LMM Duramax
    Dec 2005
    Agreed.
    Dec 2005
    I am sure most of us have backed up our CD collection. As long as you have the original copy (IE: Predator in this case) The law is on your side. Once you give/sale a copy to someone that does not have the original copy. Then you get into copyright infringments.
    I know you wanted to drop it, but I had to try and clear it up some.
  1. EFILive programmers' API
    By Blacky in forum General
    Last Post: April 24th, 2012, 11:24 AM
  2. Reading an E38 / E67 ECM
    By GMPX in forum E37, E38 & E67 PFI ECM's
    Last Post: June 6th, 2007, 07:02 PM
  3. Programmers will enjoy this
    By GMPX in forum Lounge
    Last Post: November 20th, 2006, 12:00 AM
  4. Logging question for the programmers???
    Last Post: August 24th, 2006, 08:49 AM
  5. reading pcm's
    By ace68 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 3rd, 2005, 02:52 AM
