Does it exist? I get the "unsupported" message after doing the dsp5 upgrade.\
This is a 4500-5500 truck.
Custom Tuning Services
Sorry, it doesn't exist. If I recall there was something odd about that particular OS that made it impossible to perform the DSP mods to. It is non standard compared to all other Bosch Duramax OS's.
I wonder then, what happens when you put a LD os in a MD truck (LMM).
I'm not sure, but 12617083 was the OS release prior to the oddball MD, that might be your best bet.
NOPE, will not work, results in a dead key, no crank
Is there any other os that could be flashed over os 12620015 one this 2008 kodiak thx
Its simply because the starter relay control is wired differently on the GMT-560 (kodiak) and GMT-610 (van).
Pickup cals are setup to use a high side driver in the ECM (mapped to pin XYZ on one of the ECM connectors) to apply 12v to the coil of the starter relay. Kodiak/van use a low side driver (mapped to a different pin) to apply ground to the coil of the starter relay.
Change some wires around in the harness, OR poke around in the ECM binary (to tell it which starter relay hardware config to use) and it should be easy to make a pickup OS work in a kodiak....
2005 Silverado, CC/SB, 4x4, LT, LILLY/Allison12.9s @ 108 mph
many thanks to Ross and Paul
