Results 1 to 10 of 12
Thread: 12620015 support for DSP-LMM
    Default 12620015 support for DSP-LMM
    Does it exist? I get the "unsupported" message after doing the dsp5 upgrade.\
    This is a 4500-5500 truck.
    Custom Tuning Services
    Sorry, it doesn't exist. If I recall there was something odd about that particular OS that made it impossible to perform the DSP mods to. It is non standard compared to all other Bosch Duramax OS's.
    I wonder then, what happens when you put a LD os in a MD truck (LMM).
    I'm not sure, but 12617083 was the OS release prior to the oddball MD, that might be your best bet.
    Nov 2017
    Just woundering if anyone has tried using a light truck operating system in a kodiak with os 12620015 would like to have the dsp5 but seems it might not be doable.thx
    Dec 2005
    NOPE, will not work, results in a dead key, no crank
    www.mscservices.net
    Nov 2017
    Is there any other os that could be flashed over os 12620015 one this 2008 kodiak thx
    Dec 2005
    Quote Originally Posted by Tyson View Post
    Nope, any VAN or Kodiak will not work at all with a Pickup single or DSP2 or DSP5 tune.
    You have to use correct OS for that Kodiak Only single tunes only.
    It just will not work
    www.mscservices.net
    Nov 2005
    Its simply because the starter relay control is wired differently on the GMT-560 (kodiak) and GMT-610 (van).
    Pickup cals are setup to use a high side driver in the ECM (mapped to pin XYZ on one of the ECM connectors) to apply 12v to the coil of the starter relay. Kodiak/van use a low side driver (mapped to a different pin) to apply ground to the coil of the starter relay.
    Change some wires around in the harness, OR poke around in the ECM binary (to tell it which starter relay hardware config to use) and it should be easy to make a pickup OS work in a kodiak....
    12.9s @ 108 mph
    many thanks to Ross and Paul
    Mar 2009
    I believe Josh said he did just this with the dumpster van so he could run DSP5 on it.
  1. DSP for LMM and LBZ
    By johnasara in forum General (Diesel)
    Last Post: December 23rd, 2009, 03:31 AM
  2. LMM DSP Beta1 Release
    By GMPX in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: December 19th, 2009, 11:20 AM
  3. LMM DSP switch
    By GL4662 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 19th, 2009, 08:32 AM
  4. DSP-5 for LMM???
    By flyguy_17 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: November 15th, 2008, 06:42 AM
  5. 2008 LMM support?
    By Boost in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 9th, 2007, 11:56 PM
