Results 1 to 2 of 2
Thread: scantool "mode not supported"
    Dec 2010
    Default scantool "mode not supported"
    im having a problem trying to data log after i connect to my truck and go to click on the real time data button it pulls up an error code 11: and says mode not supported. Anyone else had this problem? thanks btw its an lmm if that matters
    Oct 2004
    Hi,
    Please ensure that you don't have any non-supported PIDs selected, and also that you don;t have more than 24 channels of data selected. Probably the best thing to check first is:
    1) That you have the latest software and firmware (see below knowledgebase articles).
    2) Try logging a default PID list ('Duramax LBZ Imperial' for instance) and see if that works. If that does work then it does suggest that you have either too many PIDs, or unsupported PIDs selected.
    Knowledgebase articles for software and firmware updates:
    - Software
    - Firmware
    Andrew
    EFILive Crew
  1. Replies: 13
    Last Post: May 19th, 2011, 06:19 PM
  2. Replies: 3
    Last Post: March 6th, 2011, 02:12 PM
  3. EFILive "Classic"/"Legacy"/"Historic"?
    By emarkay in forum FlashScan V2
    Last Post: November 2nd, 2008, 02:48 AM
  4. Unsupported PID's? Making them "supported"
    By N0DIH in forum General (Petrol, Gas, Ethanol)
    Last Post: October 7th, 2008, 10:40 AM
  5. Can V2 read "non supported" cars?
    By Dale in forum General (Petrol, Gas, Ethanol)
    Last Post: March 19th, 2008, 02:21 PM
