Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: PE Mode Controls All Closed-Loop Fueling
  1. #21
    Feb 2012
    Quote Originally Posted by trimchip View Post
    If this is the case i fing it strange that in my calibration (12206911), the 3605 and 3618 consists of numbers smaller than 1, IE 0,88 multiplied with 14,63= 12,87 AFR.
    Sounds like you're viewing in Lambda, no Equivalence Ratio.
  2. #22
    May 2010
    The article starts with numbers higher than 1 giving a lower AFR.
    It`s the opposite with mine, tables B3605 and B3618 contains multipliers lower than one.
    Anyway, I`m struggling to obtain auto tune using RTACS on standard calibration file.
    I`ll start a new thread describing the case.
  3. #23
    When you view your B3605 and B3618, look in the panel in the upper right, next to Units, what does it say (EQR or Lambda, which one)...?
    See what darcy said above.
    You already know that Lambda = 1/EQR
    and that Lambda < 1 is RICHER than stoich, and Lambda < 1 is LEANER than stoich
    (and of course, EQR is the inverse).
    B3605 and B3618 are not simply "multpliers", they are EQR or Lambda (depending on how you set Fueling Units in your tunetool).
  4. #24
    For non-EFILive people reading this...
    B3618 = PE EQR table
    B3605 = OL EQR table = OLFA table (depending on the fueling units selected in the tunetool)
    B3647 = OL EQR table for COS (Custom Operating System)
    Quote Originally Posted by Dirktdolman View Post
    Can you brake the acronyms down for us slow kids? PLEASE
    DT,
    I only now saw your post...
    PE = Ppower Enrichment
    OL = Open Loop
    EQR = Equivalence Ratio = 1/Lambda
    OLFA = OL Fuel Air
    COS - Custom Operating System (i.e. for PCM).
  5. #25
    I suppose 1221256 is a misprint, and that we are actually talking about 12212156
    It was a typo, I fixed it now on Shawn's behalf (I know for fact that he ran 12212156, I was on the phone with him quite often).
  6. #26
    May 2010
    You are right (of course)
    I saw this earlier today when i was reading through the custom OS 2/3 bar tutorial. (It reads Lambda in my setup)
  7. #27
    May 2010
    Changed it under properties and restarted program.
    Now it shows EQR, and the tables changed to higher than 1
  1. No closed loop
    By fezz57 in forum Petrol / Gas
    Last Post: May 4th, 2011, 06:40 PM
  2. How to REALLY shut of closed loop/ force open loop
    By Tomato in forum Gen III V8 Specific
    Last Post: June 17th, 2008, 03:37 AM
  3. Not going into closed loop
    By tblu92 in forum Gen III V8 Specific
    Last Post: February 12th, 2008, 10:22 AM
  4. closed loop and open loop switching
    Last Post: July 10th, 2006, 08:56 PM
  5. Open Loop SD VS Closed Loop SD Advantages???
    Last Post: August 4th, 2005, 12:25 PM
