Can an EFI tune be flashed to the ECU "over" a box tune, or does the truck need to be returned to stock first?
Conversely, can a box tune be flashed over an EFI tune?
It depends what box tuned it, some lock the ecu and others dont.
Can any damage be done by trying? Will it simply either work or not?
What about a box tune over an EFI tune?
On the Cummins ECM 'everything' is written to the ECM, if you grab a tune from another truck and flash it over the top of what you currently have, your original tune is totally wiped out. To flash a Cummins it's almost at the point of it gets cloned from the file each time you flash.
I understand from that explanation that no harm will result from flashing a box tune over an EFI tune, or vice versa...
Is this an accurate statement?
I have flashed over a box tune several times...it's just erases the box tune and writes tfe efi tune over it.
You should pull the box tune first and verify in V7.5 that you have a "ok to flash" message, before you attempt a flash with efi.
~Les
Les Szmidt
2007 5.9 Dodge Ram
EFI Live Cummins BETA Tester
Silver Bullet Tuning
silverbullettuning@gmail.com
www.youtube.com/ljszmidt
What do you mean, "pull the box tune first?" Read it with EFI?
06 Laramie 3500 QC SB 4x4 - Full billet Auto by DTT, HE351/S475 twins, EFI live, lots of custom goodies....
07 6.2L Yukon Denali - CAI, CAT delete, self tuned with EFI Live
03 Trailblazer 4.2L I6 - CAI, custom exhaust, EFI live
2010 Laramie 3500 CC LB 4x4 - H&S, DPF delete, waiting for EFI Live.....
Les Szmidt
2007 5.9 Dodge Ram
Im pretty sure that most tuners will still flash even if they have been flashed over. They are still locked to the ecm, and they should just flash over the efi live tune... someone correct me if I am wrong?keep in mind that quite likely your box tuner will be rendered useless after you flash over that tune, prohibiting you from "returning to stock" and/or using it on another vehicle.
06 Dodge RCLB 2500 5.9L Hamilton, Maxxspool, Wicked Diesels, Bullseye Power, Industrial Injection, South Bend Clutch, Amsoil, K&N, ARP,EFILive, T&C Diesel, ATS, GDP...
