Hello guys, I did some searching and did not come up with any answers, so i appologize if this has been covered somewhere else....
I have upgraded my 6L80E transmission with the alto red clutch packs, welded drums, 300M shaft, and 2400 billet Stall converter. Now need to to tune this transmission to ensure it will last. My stock unit did not hold up to 10 PSI whipple on the 2010 6.2L Sierra 4wd. (clutches started to slip after a couple hundred miles even with some pressure mods.) So I am wondering if there are pids in the works to monitor adaptive shift cells (much like LTFT's) and see where I am over or under pressuring the shifts and packs. i added pressure to all shifts and made sure to leave enough time to complete them and have the transmission almost feeling stock again with TM left on. Still 2-3 shift is slightly harsh at certain rpms but I am guessing that may be attributed to the damper removal and shaft upgrade. (Not sure on this.) it's not a harmful shift but it bangs in a little more than i'd like to see on a vehicle this heavy. Are more pids in the works to really disect this tranny? Thanks guys!
