I have flashed my Cummins truck just fine. Went to flash my friend's Cummins and it flashed just fine too. Although it showed this DTC code: B2911 Module ($11) "Engine controller"
It was persistent and would not clear. An interesting thing happened, or DID NOT happen I should say. It did not use up my second Cummins VIN license on my FlashScan V2. It shows mine, but the other spot is still available. The truck had never been read or flashed with EFILive before either.
Any thoughts of what the code means on a Cummins and if this had anything to do with not using up my second Cummins VIN license on my FlashScan V2. And could this hinder my friend's Cummins truck when he goes to purchase his own FlashScan and Cummins license and tunes his truck? I talked to a well respected tuner over here in the US, and says it might just be a flub with the license thing, but I didn't ask him about the Code.
Thanks,
Andrew
