Results 1 to 3 of 3
Thread: Cadillac SRX 2011 Script file not supported
    Jun 2011
    Default Cadillac SRX 2011 Script file not supported
    Hello there,
    I was trying to read a Cadillac SRX 3.0L 2011 with E39 ecu, but I got this error: "Script file not supported by current software version".
    My software it's updated and there's communication between ECU and laptop, it recognize the ECU correctly.
    Any help in how to fix this ???
    Thank you in advance.
    Jul 2004
    It's likely an install problem, try uninstalling and then re-installing V8. That will commonly fix this.
    Ira
    And make sure you use the latest release on the main EFILive.com downloads page. I believe you cannot use V7.5 to flash the E39 and must use V8.
  1. need stock tune 2011 srx or 2010 srx
    By redonetoo in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: May 9th, 2011, 06:03 AM
  2. Can't BBX full flash (Error $0502, script file not found)
    By spandit in forum FlashScan V2 BB Logging
    Last Post: April 14th, 2011, 09:34 AM
  3. Error $0502 Script file not found
    By jcow in forum Allison 5 & 6 Speed
    Last Post: April 14th, 2011, 01:53 AM
  4. Can I get this file supported?
    By slows10 in forum IL4, 97-01 PCM and 02+ P11 PCM
    Last Post: December 12th, 2010, 06:58 AM
  5. How do I save a tune I made as a script file?
    By LBZoom in forum General (Diesel)
    Last Post: March 23rd, 2009, 06:14 AM
Tags for this Thread
