Results 1 to 2 of 2
Thread: Why reduce MAF scaling values on a basically stock E38?
    Lifetime Member Chalky's Avatar
    Sep 2003
    Question Why reduce MAF scaling values on a basically stock E38?
    Car is Z06/LS7. Just trying to understand why you would reduce MAF scaling on one or both tables and then alter injector tables? I know soem tuners use injector tables to achieve desired AFR's. I just don't see why you would reduce MAF scales as part of the tune. If anything, the car is seeing more air do to headers and an improved intake system.
    2015 Z06 A8
    Dec 2007
    Quote Originally Posted by Chalky View Post
    Dont know why anyone would touch the injector tables, but if you have changed the intake before the throttle body unlikely the MAF will still provide an accurate reading.
  1. Replies: 0
    Last Post: June 2nd, 2011, 05:12 AM
  2. Does B0141 actually do anything (stock values set to 0.1...?)
    By MadMaxHSV in forum Gen IV V8 Specific
    Last Post: February 18th, 2011, 06:31 PM
  3. Replies: 10
    Last Post: August 27th, 2009, 10:38 AM
  4. How can I reduce BEN Map values by 50%?
    Last Post: April 23rd, 2007, 02:05 AM
  5. DESIAC_B values and MAF values keep trimming down. Help!
    By ArKay99 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 12th, 2005, 01:54 PM
