Results 1 to 5 of 5
Thread: Possible timing issue?
    Lifetime Member LBZoom's Avatar
    Jun 2008
    Default Possible timing issue?
    Hey guys,
    Been working with a local guy here with a 2006 5.9L mega cab, automatic. Everything uploaded and downloaded fine, truck started right up.
    I flashed a tune in yesterday, worked fine in the test drive but had a little more rattle in the mid range. Today he went to drive it and it white smokes at idle, and has a very loud rattle. I never adjusted timing in the idle range though....
    Any thoughts on where to looK? He did tell me he has suspected his injectors may be on the outs, but I haven't had a chance to log and verify since then. What PID's do I need to select to log that for those of you who already know?
    Thanks in advance for the help!
    Peace Through Torque
    Punisher Performance DSP5 Tuning, PPE Dual CP3's, 68mm Fleece Cheetah, Punisher Built trans w/ Suncoast Parts, Airdog 165, SoCal 100% Overs, ARP Studs
    2013 NHRDA Sportsman World Champion
    www.PunisherPerformance.com
    Nov 2010
    Had you modified pilot injection amount??
    I know with mine, if I had too little pilot at cold idle, it has like doodoo and white smoked.
    ~Les
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Aug 2009
    I dont suggest you make any changes without logging them.
    log the injection timing, rail pressure too
    Lifetime Member FUBAR's Avatar
    Feb 2011
    I know mine rattles when pilot shuts off around mid range. Fuel Balance cylinder rates are what to look at logging. But for now till next release, balance rates do not work correctly.
    -Andrew
    06 LBZ, EFILive
    Nov 2010
    New update posted to fix issues...along with balance rates.
    ~Les
    Les Szmidt
    2007 5.9 Dodge Ram
  1. loosing sleep over my 1998 454 -compcams timing issue
    By camminchevy in forum Vortec V6/V8 Specific
    Last Post: April 29th, 2011, 06:01 AM
  2. Timing issue w/'02 Camaro tune on '95 LT1
    By schwoch1 in forum Gen III V8 Specific
    Last Post: March 17th, 2010, 03:11 PM
  3. Ignition timing issue,bank to bank
    By AllOutPerformance in forum Gen III V8 Specific
    Last Post: December 5th, 2009, 11:38 AM
  4. Billet LT1 Timing Cover - Clears Double Row Timing Chain
    By S10Wildside in forum Conversions / Aftermarket Parts
    Last Post: November 17th, 2009, 12:15 AM
  5. LMM timing limiter and pilot issue
    By camcojb in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: April 4th, 2009, 02:48 PM
Tags for this Thread
