Results 1 to 10 of 12
Thread: Nothing works nor does it make sence.
    Feb 2007
    Default Nothing works nor does it make sence.
    Have a new laptop. Running windows 7. :(
    Started off i had to downgrade the usb thing other wise whenever plugged in it would be frozen.
    I then got it to check OK. Tryin to read a trucks tune before update to dsp5. Well I get an error. I've tried to upgrade the boot and firmware but nothing is working for me.
    I plug in the v2 and it sees it there then turns to not responding. I have uploaded a bunch of screen shots attempting to show how everything is failing...
    Thx
Name:	efi fucked.jpg
ID:	11204   Click image for larger version.
Name:	efi no respond.jpg
ID:	11205   Click image for larger version.
Name:	efi flash specs.jpg
ID:	11206   Click image for larger version.
Name:	efi fucked 2.jpg
ID:	11207   Click image for larger version.
    Please install the version 8 software, then follow the instructions in this document to update your FlashScan firmware.
    Start->All Programs->EFILive=>V8->Documents->Upgrading Firmware
    The current versions that you should have installed as at June 26, 2011 are:
    V7.5.7 build 165
    V8.2.1 build 156
    FlashScan V2 Boot block V2.07.02
    FlashScan V2 firmware V2.07.12
    Please also see this page for a couple of important issues that you may strike with the latest release:
    http://forum.efilive.com/showthread....e-June-06-2011
    Feb 2007
    Thanks, i'd went through that pdf erlier but for whatever reason didn't understand the boot block upgrade being done with the v2. I have it all upgraded to the specs you listed. Hopefully tomorrow i can plug her in and try to read then program a truck.
    Thx for quick reply
    Feb 2007
    Just tried it and fail again.... I copied the info in hopes it will make sence.
    18:08:34.951: Scanning for EFILive FlashScan V2 HAPI
    18:08:34.967: Autodetect interface ...
    18:08:35.138: Interface firmware version: 2.7.12
    18:08:35.138: Connection to [FSV2] interface is OK
    18:08:35.154: USB driver version: 4.0.0
    18:08:35.154: USB library version: 3.1.18
    18:08:35.169: Interface firmware model: FSV2
    18:08:35.185: Interface firmware model: FSV2
    18:08:35.185: Interface firmware version: 2.7.12
    18:08:35.201: Interface firmware date: Jun 06, 2011
    18:08:35.216: FlashScan serial number: 003599133600
    18:08:35.232: FlashScan license number: 003599133600
    18:08:35.247: Disconnecting ...
    18:08:35.669: CAN-VPW Bridge Deactivated
    18:08:35.669: Disconnected
    18:08:36.324: Scanning for EFILive FlashScan V2 HAPI
    18:08:36.339: Autodetect interface ...
    18:08:36.573: Interface firmware version: 2.7.12
    18:08:36.589: Connection to [FSV2] interface is OK
    18:08:36.589: CAN-VPW Bridge Activated
    18:08:36.667: Current protocol set to: "ISO 15765 CAN"
    18:08:36.667: Autodetect ECM...
    18:08:36.714: Connection to ECM is OK
    18:08:36.729: Current protocol: "ISO 15765 CAN"
    18:08:36.948: USB driver version: 4.0.0
    18:08:36.948: USB library version: 3.1.18
    18:08:36.963: Interface firmware model: FSV2
    18:08:36.979: Interface firmware model: FSV2
    18:08:36.995: Interface firmware version: 2.7.12
    18:08:37.010: Interface firmware date: Jun 06, 2011
    18:08:37.026: FlashScan serial number: 003599133600
    18:08:37.041: FlashScan license number: 003599133600
    18:08:37.322: Getting status...
    18:08:37.556: Status: OK.
    18:08:37.556: Request VIN...
    18:08:38.211: VIN: 1GCHK34D86E160652
    18:08:38.945: Preparing ECM for reading flash...
    18:08:38.991: ECM seed is: $47F4
    18:08:38.991: Unlock attempt 1 of 1
    18:08:39.132: Initializing ECM...
    18:08:40.505: Error: Failed. Controller has returned to normal operation, please retry the operation.
    18:08:41.144: Total time: 00:00
    18:08:41.144: Rebooting ECM... (please wait up to 8 seconds)
    18:08:42.314: ECM has booted successfully...
    18:08:43.328: Clear emisison related DTCs...
    18:08:43.359: Clear DTCs for all modules...
    18:08:45.512: Autodetect interface ...
    18:08:45.746: Interface firmware version: 2.7.12
    18:08:45.746: Connection to [FSV2] interface is OK
    18:08:45.746: Autodetect ECM...
    18:08:45.809: Connection to ECM is OK
    18:08:47.103: Disconnecting ...
    18:08:47.712: CAN-VPW Bridge Deactivated
    18:08:47.712: Disconnected
    18:11:22.362: Done!
    Now it seems to have an issue after unlock attempt 1 of 1.
    Can you please locate the matching *.blx file that should have been logged when you attempted to read the controller.
    The file will be be in the folder called \My Documents\EFILive\V7.5\Bug Reports\
    and called something like YYYYMMDD_HHMMSS_upload.blx
    where YYYYMMDD is the year, month and day, and HHMMSS is the hour, minute and second that you attempted to read the controller.
    Please email me that file to paul@efilive.com
    Feb 2007
Name:	efi error  june23.jpg
    Feb 2007
    Thanks, found it and sent the email!!
    It looks like the truck already has a DSP5 tune in it. If that is the case then there is no way to read the tune out.
    All DSP5 tunes are protected from reading. You should be able to flash over it with a new tune if you want to.
    You can verify if it is a DSP5 tune or not by checking the Operating System Number of the controller in the V7 Tune Tool on the menu: Flash->Show PCM Info.
    If the OS number starts with the digit "5" then it is a DSP5 tune.
  1. Im addicted to all this..... Can someone sence check my tune....
    By Behold in forum General (Petrol, Gas, Ethanol)
    Last Post: June 3rd, 2011, 10:38 AM
  2. It works in VirtualBox!
    By endo in forum EFILive on Linux
    Last Post: August 27th, 2010, 12:06 AM
  3. Windows 7 - Just Works
    By NERDPWR in forum Lounge
    Last Post: June 12th, 2009, 05:16 AM
  4. Let's see if this works...
    By SSpdDmon in forum Gen III V8 Specific
    Last Post: June 26th, 2007, 03:20 PM
