Just put on a Flex-A-Lite dual electric fan kit on my 2002 silverado. Followed all the directions for wiring and installation. But now when i turn the key into the "start" position, my truck goes haywire. The front differential shifts, lights turn on and off, my gauges don't show my fuel level or anything. I've checked all the ignition fuses and they're all good, and all the connections for my wiring, and they're all good as well.
I need my truck this weekend as i'm moving out of Province.
I have a few codes coming up.
SRS U1000
SRS U1064
SRS U1096
PCM 0300
$10 PayPal For Person Who Helps Me Fix Problem
Battery is 12.47v at rest, i do not know the voltage under load when cranking, I have checked all the fuses and they are intact none are blown.
I have disconnected the electric fan all together and started the truck and it gives me the misfire code, and yes, it is very much so missing. The passenger side is dumping moisture out the tail pipe pretty bad(true dual).
