Page 11 of 11 FirstFirst ... 91011
Results 101 to 109 of 109
Thread: Fuel_Economy calculated pid?
  1. #101
    Jul 2009
    Hey guys Ive tried doing this,and it wouldnt work. Said the pid I have selected is n/a, and wouldnt display it since it is n/a. Any ideas? I can see the mpg pid in the data, but it reads n/a?
  2. #102
    Feb 2013
    Has anyone used the MPG calc pid with big injectors? The equation should account for the injector size, but some people are saying the pulse width might be too low with big injectors. I cruise at 3.2ms and idle at 2.1ms. They are 72# @ 3bar Bosch injectors from FIC. According to the calc pid, my cruise fuel economy went from 19-20mpg with stock 25# injectors to 12-13mpg with the 72# injectors. The actual fuel economy appears to be much lower as well. Just trying to figure out if an error in the calc pid is partially to blame. Here is mine:
    MPG(mi/gal) = {SAE.VSS.mph}/({GM.INJFLOW.lbpm}*(({GM.IBPW1}+{GM.IBPW1})/2)*{SAE.RPM}*4/6073)
    2001 Silverado 5.3L ECSB 2WD T56:
    T76 turbo, Meth injection, 72# injectors, 799 heads, 212/212 114LSA cam, Built 4L80E, 3.42's
    EFILive V1 Commercial, COS5 2-bar SOLSD, AEM wideband
  3. #103
    Quote Originally Posted by rennoc442 View Post
    On the PIDs tab, on the MPG pid do rightclick->More Info and take note of all the pids mentioned... then go and select all those pids.
  4. #104
    Dec 2010
    November 18th, 2009
    Your slipping joe...
    I found this thread couple weeks ago and the MPG PID works great, but have to check and see if you have your liters and gallons mixed up.
  5. #105
    Jan 2013
    Quote Originally Posted by dc_justin View Post
    4 and 6250 accomplish that.
    I don't have my notepad in front of my that accomplished all of this, but the only constant you need (I think) is the weight of gasoline at 6.25lb/gal (thanks google).
    I was about to log some data and as I'm using imperial gallons (not US) I think I just need to change 6250 in the equation to 7500 to account for the bigger gallon measurement used here? Imperial gallon being 20% more volume.
  6. #106
    Dec 2010
    What is the purpose of this PID and 2 "GM.IBPW1" then divide by 2?
    "MPG(mi/gal) = {SAE.VSS.mph}/({GM.INJFLOW.lbpm}*(({GM.IBPW1}+{GM.IBPW1})/2)*{SAE.RPM}*4/6073)"
    Also looks like the weight of fuel has changed from 6250 to 6073? Could this be an E fuel adjustment?
  7. #107
    Feb 2013
    Quote Originally Posted by EagleMark View Post
    It averages the two injector pulse widths because they may not be the same. As for the fuel density, not sure where that value came from. But you'll find a wide range of values depending on where you look.
  8. #108
    Dec 2010
    Shouldn't that be "(({GM.IBPW1}+{GM.IBPW2})" notice 1 and 2... the origianl is 1 and 1... ?
  9. #109
    Feb 2013
    Good catch, typo
  1. Calculated PID's
    By Jason S. in forum General (Petrol, Gas, Ethanol)
    Last Post: March 17th, 2007, 09:55 AM
  2. Calculated PID Problem
    By NewV in forum General (Petrol, Gas, Ethanol)
    Last Post: December 12th, 2006, 09:44 AM
  3. LM1 Calculated AFR PID
    By VetPet in forum General (Petrol, Gas, Ethanol)
    Last Post: September 3rd, 2006, 03:04 AM
  4. calculated value question
    By evil in forum Tips and tricks
    Last Post: November 19th, 2003, 02:34 PM
