Page 1 of 11 123 ... LastLast
Results 1 to 10 of 106
Thread: Public Release Update June 24, 2011
    Default Public Release Update June 24, 2011
    The EFILive V7.5 and V8 software is available for download.
    This release includes the 5.9 Cummins Scanning and Tuning support.
    Read more about the Cummins features here:
    http://forum.efilive.com/showthread....Public-Release
    Download here:
    http://www.efilive.com/index.php?opt...=48&Itemid=133
    Auto Update:
    The Auto Update option is scheduled to be activated on Monday June 27 US time. Until then you need to download and install the software manually.
    Once the Auto Update option is activated your system will see it as a new update and download and install it, regardless of whether you have downloaded and installed this release manually or not.
    Known Issues:
    Issue #1
    Some PC's/laptops will freeze when attempting to start the V7.5 Tuning Tool software while FlashScan and/or AutoCal is connected. The problem appears to be an incompatibility between the newest USB drivers and some customer's PC/laptop configurations.
    Please revert back to the older USB drivers. To do that, select Start->All Programs->EFILive->V8->Tools->USB Manager, then click on the [Install USB V2.02.04] button.
    Issue #2
    If you select a Cummins controller in the V7.5 software, the GM enhanced PIDs will be removed from the scan charts and replaced by the term "Unused". Those PIDs are not restored even after re-selecting a GM controller.
    Issue #3
    The Allison 5 speed full flash does not work. There is currently no workaround.
    Reporting Issues:
    If you discover any serious problems/faults, please create a support case here:
    http://support.efilive.com/
    If you discover simple/trivial issues, please make a note of them in this thread.
    What's new in this update:
    V7.5.7 Build 167 (June 24, 2011)
    • Updated Cummins calibrations to include
      • Speed Limiter adjustment.
      • Tire size adjustment.
      • Intake Air Heater control.
    • Added speed limiter calibrations for all E39 & E78 OS's
    • Added support for E39 OS 12646099
    • Added support for E37 OS 12628961
    • Fixed potential checksum error with E39 OS 12643377.
    • Fixed axis error for table B0183 on all E37 OS's
    • Fixed scaling on dynamic vehicle testing controls.
    • Fixed scaling for Cummins injector balance rate Scan Tool PIDs.
    • Added transmission self clean DVT control for T43.
    • Fixed phantom DTC B2011 that sometimes appears after a reflash attempt on Cummins controllers.
    • Fixed DTC display in V7.5 Scan Tool for Cummins controllers.
    • Added new controllers to the auto-detect matrix for V8 software.
    V8.2.1 Build 158 (June 24, 2011)
    • Fixed script files not being updated when clicking the [Program] button.
    • Added "*.tun" file option to Windows XP open file dialog boxes.
    • When "saving for remote flashing" the software now warns the user if the filename exceedes the filename length limit for FlashSCan/AutoCal devices.
    • EFILive HAPI now correctly processes the Windows shutdown command and shuts down silently when Windows shuts down.
    • All script files (*.obj) have had their version numbers increased and must be updated on customer's AutoCal and FlashScan devices. Otherwise they may end up with $050B "Script file not supported by current firmware version" errors.
    FlashScan/AutoCal Firmware V2.07.13 (Jun 23, 2011)
    • Fixed DTC display for Cummins controllers.
    Last edited by Blacky; July 3rd, 2011 at 03:04 PM. Reason: Corrected V7.5 build number from 168 to 167
    Apr 2008
    I just updated to the newest firmware for my FlashScan. I did a" Program all required data" to update the Flash Scan. I am receiving an Error $0149 Write Failure towards the end of the programing. Any ideas?
    Quote Originally Posted by nm2769 View Post
    Do you have too many files in the Config space...?
    Format the Config space and do the Program All Data again.
    $0194 usually means "file system full".
    It may also be the case now that trying to select ALL controllers for both flashing and scanning will not fit into the config area.
    So you may need to un-check some controllers that you won't be using.
    But definitely do what Joe suggested and format the config file system as that will remove any old/unused files and will free up some space.
    Hint: the DTC description files take up the most room so by un-checking them (on the DTC tab page) you can save a lot of space.
    Except that you won't be able to display DTC descriptions on FlashScan's screen.
    You should never select the DTC descriptions for AutoCal devices - since AutoCal cannot display DTC descriptions.
    Apr 2008
    I only have 2 controllers selected and the meter at the bottom of the page shows 52% free space. I will try to format config file. thanks for the quick response.
    Nov 2009
    Mine gave me a checksum error of a cummins file I just previously built...it gives me the option to update checksums, not sure what the error is. New one for me.
    -Kory
    http://www.PPEI.com/
    Lifetime Member 06redram's Avatar
    Jan 2011
    I keep getting invalid floating point operation Over top of the message it says: EFILive Tune-Digital tools for onboard vehicle electronics
    Dec 2006
    V7 on the download page shows Build 167 above you say it is Build 168 is this a typo
    Apr 2008
    Man what is going on with this latest update? Scan tool is possessed the dash board charts are changing to random PID's and asking to save as a different dash that I don't have open. I have rebuilt my Dash B three time today once saved and reopen it is a blank screen. I have uninstalled cleaned and reinstalled and same issue is happening. I have been working with EFI Live for 3 years and i have not had this much trouble since day one. Any Ideas?
    Quote Originally Posted by Duramax 6.6L View Post
    Yes it was a typo, fixed now, thanks.
  1. Public Release June 03, 2011
    Last Post: July 9th, 2011, 07:59 AM
  2. Public Release Update June 06, 2011
    Last Post: June 20th, 2011, 07:12 AM
  3. Official Public Release - Mar 20, 2011
    Last Post: April 2nd, 2011, 10:02 AM
  4. January 31st 2011 pre-release (Updated Feb 03, 2011)
    Last Post: February 24th, 2011, 06:14 PM
