LC-1 WBO2
There may be other files already on the device that are taking up space.
Using EFILive_Explorer, how much space is shown as used/free when you click the [Properties] button on the [Config] tab page?
However, $0194 is a "general write failure", so if it is not occurring because of file system full then there may be a fault with the flash memory.
It might be useful to run a flash memory check.
You can do that by selecting F4: Options -> F4: Self Tests -> F4 (hidden option).
Press Ok to clear the message about needing a second FlashScan device.
Then select option "2.ROM" to test the flash memory.
Note: You'll need to reformat the [Config] file system after the test because the test completely erases the Config file system.
E35B codes P2033 and p0546 showing up on V7 scantool as from the TCM?? codes are turned off in ECM tune (DPF delete). Don't seem to be causing any issues, maybe phantom codes similar to B2911 in cummins ECM?
I will send you the file with the bad checksum paul. I was able to script the tune and load it to the same OS and had no issue. The problem i assume was editiing with the old software and the new upload, oddly it is the only file that is acting as though it somehow corrupted. Tahnks, i will send it on to you
CANNOT FULL FLASH AL5 ALLISON TCM. After it erased tcm it then hesitated and repeatedly said retrying previous block, after five minutes i stopped it. now when i try again it counts to 120 erasing flash memory then says flash failed. i have removed and reinstalled and am using old USB drivers
Issues continue with the latest update. The biggest problem issue is the scan tool freezing when disconnecting from a Cummins ECU. It does not freeze with LS1B ECU. I have to disconnect the USB cord to get the Scan Tool to unfreeze. I had left the USB connected and froze for 15 minutes before pulling the plug. It freezes every time I disconnect from Cummins ECU. Also I am now getting an error 1400 when I close the Tune Tool. The error pops up 5 times each time I close the tune tool.
