Hi just trying to locate factory file 24254909. Had a look on holdencrazy but was unable to find one.
This is out of a Holden Maloo
I have to check later today, but that may be the OS I am working with and I have a stock file for it. Is that a truck file you're working with?
Hello Picto,
OS 24254909 is a 6L80 OS - and was used in North American built 2010 truck / SUV models. Do you need a 4 x 2 or 4 x 4 tune ? What engine / ECM OS will this TCM tune be paired with ?
Regards,
Taz
Its out of a 2009/2010 Holden VE 6.2ls3 maloo ute 2x4
engine op system is 12635863
That is the Trans operating sys I have, but I have a 4x4. Not sure if this will help at all. Let me know if you need it...
Hello Picto,
Checking to see if I have anything that is a probable fit ......
Can you post the calibration numbers from your ECM:
I have learned the hard way that E38 / T43 combinations can be a little "fussy" in how they communicate ...
- OS
- engine OP
- system
- slave OS
Regards,
Taz
It doesn't really matter if it's 4x4 or RWD trans from an OS calibration standpoint. Tire size, axle gear, etc. are what will play the significant roles in driveability and these settings can be altered with EFILive. I've got a 4x4 6L90 running a mixed concoction of CTS-V, Commodore GTS, and Camaro calibrations.
Trailblazer "RS" 5.3L 6L80 4x4 & '07 TBSS LS2 6L90 AWD
Note...I didn't say that different platform to platform calibrations don't matter....I stated that RWD to 4WD don't matter.
