Thread: 2006 gmc yukon denali xl
    Member JST's Avatar
    Jul 2007
    Default 2006 gmc yukon denali xl
    What ecm is in this truck ? can not get in to it with my V-2
    2002 GMC 2500HD 4x4 SCLB STOCK MOTOR WITH TOMAN TUNING,FASS 150, M/A TRANS,11.90 ON A GOOD DAY IT'S MY WORK TRUCK,19 TO 21 MPG WITH ME DRIVING,THE TRUCK (OLD RED )HAS 909,000 MILE AND LOVING IT,285/75/16
    Ls1b
    Member JST's Avatar
    Jul 2007
    But it is a E-67 GEN 4 to scan it ? looked at the vin and it is a 2007 ? title is a 06 ??? not good
    Aug 2010
    Hello JST,
    A 2006 GMC Yukon would have rolled off the assembly line using an LS1-B PCM to control the engine and transmission. A 2007 model would have used an E38 ECM and T43 TCM (6L80 transmission) or a T42 TCM (4L65 transmission).
    If you have doubts as to the actual vehicle model year - visually confirm the PCM (or ECM) - either will be mounted under the hood, on the drivers side, near the battery.
    If the truck is a 2006 model, using a PCM, when you attempt to connect with the Scan Tool - select "LS1B Gen III 99-08 PCM" from the controller drop down menu options.
    Regards,
    Taz
    Member JST's Avatar
    Jul 2007
    Thanks for all the help
    Id check the VIN both on the dashboard and on the drivers side door, if they match then Id bet its an 07.
    Easy way to tell, is it a new body style Yukon or old body style? OBS = LS1B 1MB PCM, NBS = E38 2MB ECM + T42 (4speed) or T43 (6speed) trans.
  1. EBCM setup / '03 Yukon Denali
    By Boost in forum Gen III V8 Specific
    Last Post: December 17th, 2009, 05:03 AM
  2. Anyone Have A Tune 04 Gmc Yukon 5.3?
    By turboolds in forum Gen III V8 Specific
    Last Post: September 21st, 2008, 07:03 AM
  3. Denali?
    By GmcLbz in forum General (Petrol, Gas, Ethanol)
    Last Post: February 20th, 2008, 04:06 PM
  4. Gmc Yukon Immo
    By car_tech4 in forum Gen III V8 Specific
    Last Post: November 19th, 2006, 03:24 PM
  5. 2006 GMC Sierra 5.3L ???
    By chatcher in forum General
    Last Post: April 12th, 2006, 01:18 PM
