Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Script exited.....
    Oct 2009
    Default Script exited.....
    While trying to read out my stock tune im getting a message of.....
    Script exited with code $0311
    mode not supported ($11)
    I did the check for up dates in both and tried again and got the same messages.
    Any help would be very appreciated!
    Thanks,
    Buddy
    06 3500
    EFI by Rob @ ATP
    Nov 2010
    How many times did you try??
    Sometimes I get that error while flashing, I just reflash and it seems to work.
    ~Les
    Les Szmidt
    2007 5.9 Dodge Ram
    EFI Live Cummins BETA Tester
    Silver Bullet Tuning
    silverbullettuning@gmail.com
    www.youtube.com/ljszmidt
    Oct 2009
    Hi Les, ive tried about 5 times now and the same messages come up, this is the first time ive had the V2 connected to the truck.
    06 3500
    EFI by Rob @ ATP
    Lifetime Member IdahoRob's Avatar
    Apr 2006
    We've got him set-up with the latest firmware and software versions, so that isn't the issue. I have another customer that has this issue with a stand alone ecm in a race truck. I had that customer check on another truck to see if it's the ecm or software and his works fine on other trucks, so I recommended to have Mr. BSwope try this.
    2013 LML, 550hp with factory emissions, stock cp4 and compound turbos.
    2002 LBZ, 4x4 (Max'd Out) 6000lbs 9.36 @ 154 mph NHRDA Champion and Record holder
    1965 El Camino, duramax 9.6 @ 149MPH
    All EFI tuned by Adrenaline Truck Performance
    Oct 2009
    Rob, thank you very much for calling me, customer service 110%! As soon as I get ahold of my freind and his 06 Ill let ya know how things go!
    Thanks again Rob,
    Buddy
    06 3500
    EFI by Rob @ ATP
    Quote Originally Posted by BSwope View Post
    How far in to the read before the error pops up?
    Apr 2006
    I believe instantly. Soon as he hits go.
    Oct 2009
    Yep Rob is right, It reads till it says something like, script read, script accepted and then a few seconds later the messages appear...
    06 3500
    EFI by Rob @ ATP
    Lifetime Member DoghouseDiesel's Avatar
    Dec 2009
    Are you trying to read a truck that has or has had one of the Smarty's with the POD function?
    If so, it won't read it. It won't read it if you set it back to stock either. It's something with the POD function.
    I've had to reflash it with a stock file before I was able to get it to read.
    Now, it will read any of them that do not have the POD function.
    1207 HP / 1612 TQ
    Oct 2009
    Quote Originally Posted by DoghouseDiesel View Post
    Yep..... I had the SSR for a few weeks and by the sounds of things it was a few weeks too long!
    So I looks like ill need to flash a new stock file in, dang Smarty anyway!
    06 3500
    EFI by Rob @ ATP
  1. script question
    By bmax in forum Tips and tricks
    Last Post: October 5th, 2012, 09:55 PM
  2. Script help!
    By speedygoss in forum Duramax LLY
    Last Post: March 6th, 2011, 06:20 AM
  3. Script ?
    By GAMEOVER in forum General (Petrol, Gas, Ethanol)
    Last Post: January 1st, 2009, 06:46 PM
  4. The new script feature
    By Dirk Diggler in forum General (Petrol, Gas, Ethanol)
    Last Post: May 21st, 2008, 11:36 AM
  5. Script help
    Last Post: February 27th, 2006, 03:07 PM
