Results 1 to 3 of 3
Thread: lm-1 wide band
    Dec 2005
    Default lm-1 wide band
    i have a lm1 wide band i take it if you just configure it to analog out like the lc-1 it will work the same allso has any one tryed using the lc-1 like a narrow band or lambda though the stock wiring then just datalog the voltage then you could just do the math on voltage to get the air fuel off lambda and use other analog out for there programable display meter any input thanks
    Oct 2005
    I have datalogged the voltage no problem through the stock wiring no problem, fwiw.
    Oct 2005
    It works fine, but if you log the nb sim, you wont get much detailed info.
    If you are using it to tune VE you are better off logging it as WB in flashscan for a while and gettting that sorted first, you can then wire up the gauge afterwards.
    2014 VF SV LS3 Maloo.
  1. looking to buy a wide band?
    By jeff keyuk in forum Lounge
    Last Post: June 7th, 2010, 08:07 AM
  2. Wide band
    By Harrismarine in forum FlashScan V2
    Last Post: July 6th, 2008, 12:27 PM
  3. Wide band question??
    By gotabav in forum General (Petrol, Gas, Ethanol)
    Last Post: May 11th, 2008, 04:43 PM
  4. The Wide Band....how do we really know...
    By Redline Motorsports in forum General
    Last Post: January 8th, 2007, 06:51 AM
  5. wide band o2
    By woody69 in forum Custom Operating Systems
    Last Post: October 23rd, 2006, 04:19 PM
