Wondering if I can install an auxillary temperature sensor and use the pcm to control a 12v output (like a fan relay). Anything come to mind? For instance a temp sender mounted on an intercooler triggering a fan relay if a certain temp is satisfied.
You don't need the PCM's involvement to do that; just get a "temperature switch" and wire it to trigger a relay, there are tons on fleabay for $25-50.
Mr. P.
2003 Silverado SS, with Novi-1500 "CAI mod"
EFILive V 7.5 COS-3 (OLSD, for now!)
Is this for an air-to-water heat exchanger, when the vehicle is stopped and there's no airflow to cool it so you activate a dedicated fan??
