Results 1 to 3 of 3
Thread: mafless/pcm
    Dec 2004
    Default mafless/pcm
    when my car was mafless tuned with edit.the tuner changed the computer.while he was tuning with each flash he enterd a vin not mine i dont think.till he was finished.at wich time he entered mine using a diferent cable from under the dash..can i expect any probs when my flashscan arrives.. car is vu ute a4..
    If it was tuned with Edit there should be no problems.
    Not sure what was going on with the VIN.
    Quote Originally Posted by GMPX
    The PCM came out of a different car , final part of the tune is to get all the values in the PCM to line up with your vehicle.
    You will need to get your PCM back to your tuner as all mafless tunes are locked so flashscan will not read it without the pcm being put back to std.
    you may ( or will find ) it was not tuned with edit but with flashscan - just a early beta version of flashscan
  1. MAFless??????
    By Rvettej in forum Gen IV V8 Specific
    Last Post: June 25th, 2021, 12:20 AM
  2. Going MAFLESS and O2 less
    By The Alchemist in forum E37, E38 & E67 PFI ECM's
    Last Post: February 12th, 2008, 09:08 AM
  3. Going mafless On a E-40...anytips?
    By FFP in forum Gen IV V8 Specific
    Last Post: August 13th, 2007, 06:40 AM
  4. Question about going MAFless
    By VortechC5 in forum General (Petrol, Gas, Ethanol)
    Last Post: September 26th, 2005, 02:24 AM
