I was wondering if i could get a few tips on maken a mileage tune. the one i have so far doesnt seem to be doin better than about 16mpg on the interstate and same in town.
fill out your sig so we can better help you... have you contacted who you got the tune from?
this is actually for a friend of mines truck all it has on it is intake fass and exhaust and a dsp5 that we have been playing with
here is the tune file it would be number 2 on the switch so slot 1 on the dsp program mwdspmod.tun
Just to give some thought, in the part throttle areas, under 20 mm3, decrease boost, and increase timing.
Also suggest playing/reducing pilot injection timing, (2 and 3 off).
Custom Tuning Services
So I am a gas guy.. Decrease boost. Would you need to pull some fuel out also besides the Pilots? And what about post injections?
Mike
Mileage is all about efficient power, too much power is a waste, and too little power causes your engine to work harder. Pulling fuel besides the post/pilot injections won't do much of anything except turn your truck into a dog....
Timing and boost are your biggest contributors, a lot of guys recommend pulling some boost but personally I've never had any luck with that....
Reducing restrictions in your airflow system has the same effect as lowering boost without the potential loss of response, the easier the air flows the less friction and heat is generated in the motor, and the components don't have to work so hard to make power. You're able to flow more air volume @ same boost pressures.
That's just a quick reference, hope it helps some!
Peace Through Torque
Punisher Performance DSP5 Tuning, PPE Dual CP3's, 68mm Fleece Cheetah, Punisher Built trans w/ Suncoast Parts, Airdog 165, SoCal 100% Overs, ARP Studs
2013 NHRDA Sportsman World Champion
www.PunisherPerformance.com
