Results 31 to 38 of 38
Thread: Tips & Tricks: Things you've learned while exploring EFI Live on the Cummins
  1. #31
    Jun 2011
    Quote Originally Posted by LReiff View Post
    Moving it up past 22 degrees has been detrimental. LOL
    How so?
  2. #32
    Jun 2011
    Quote Originally Posted by MQ105 View Post
    How so?
    Instead of 20 and 14 in the last two cells I made it 25 and 27 respectively. The motor made popping noises and acted alot like the timing was retarded. This only happened once the engine hit the respective rpm.
  3. #33
    Jun 2011
    Was this with a lot of duration?
  4. #34
    Jul 2011
    How do the air density adjust tables work into the mix?
  5. #35
    Junior Member chance cobb's Avatar
    Jun 2011
    cool thing i found today while playing around is when you are logging your truck and you click back to the tune tool you can see what the truck is doing in live time on the slected map it just highlights the the map that the cem is using or what ever .
  6. #36
    Apr 2014
    why on a completely stock file it is a lot higher for that table 42 down too 34 degrees on a bone stock file
  7. #37
    Jan 2016
    This is a great thread, keep it going!
  8. #38
    Dec 2013
    From 4 almost 5 years ago... lol
  1. Idle Tips & Tricks
    Last Post: September 7th, 2018, 08:04 PM
  2. Banks iQ & EFI Live ????
    By Spuco in forum FlashScan V2
    Last Post: January 2nd, 2010, 01:16 AM
  3. EFI LIVE & HPTUNERS compatibility?
    By Rich Z in forum General (Petrol, Gas, Ethanol)
    Last Post: January 1st, 2008, 11:46 AM
  4. RTACS tricks and tips................
    By Redline Motorsports in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 25th, 2007, 01:27 PM
