Results 1 to 10 of 16
Thread: Autocal calibration file storage capacity
    Default Autocal calibration file storage capacity
    I am trying to load an Autocal with two engine calibrations and two transmission calibrations. The is for an E38/T43 vehicle application so each CTD file is roughly 2 MB. I can only load 3 files.
    Is that the limit or does a method exist to actually have up to 5 calibration files on the device at once?
    Jason Haines, Project Director
    Lingenfelter Performance Engineering
    http://www.lingenfelter.com
    jhaines@lingenfelter.com
    260-724-2552
    Jun 2011
    Quote Originally Posted by jrh View Post
    That's it,,,you cant do anything about it
    That is what I was afraid of. I hope they add more memory capacity or come up with a more compact storage format.
    Quote Originally Posted by av08 View Post
    260-724-2552
    I am working on that. The compact file format that will contain just the calibration section which will only be about 300-400KB.
    You'd get about 10 cal-only tune files onto AutoCal.
    The only limitation is you won't be able to do a full flash with those cal-only files.
    Jun 2011
    what does full flash mean? in autocal there is prog 1 and full1 what is the difference?
    A calibration-only flash only reprograms the calibration data.
    A full-flash reprograms the calibration data and the operating system program code.
    On some controllers the full-flash even erases and rewrites the boot loader code in the controller. That means if a full flash fails on those controllers after the boot loader code has been erased but before it has been re-programmed back into the controller, then the controller has no way of communicating with the outside world and is dead. The only way to recover a controller in that condition is to remove (de-solder) the flash memory chip from the controller's circuit board and reprogram it using a chip programmer, then resolder it back again.
    Because a full-flash can potentially kill a controller, you should always use cal-only flash unless there is a real need to change/update the operating system. For example when installing an EFILive custom operating system.
    Nov 2007
    Hey Paul, I am NOT getting on your case, but would it have been a big deal to make these
    devices (v2 and autocal) with more memory ?
    -Justin
    Quote Originally Posted by L31Sleeper View Post
    -Justin
    Yes it would have been, (hindsight is wonderful) but at the time FS V2 was designed, 4MB was all we could fit on the boards (since upgraded to 8MB) and it was never an issue because it had the capability for an SD card.
    When we designed AutoCal it had to function using the same firmware and 90% of the same parts as FlashScan, so it too was limited to 8MB. The 8MB was considered large enough at the time because we anticipated much smaller *.ctd files.
    Jun 2011
    Great! info, is this documented anywhere?
    Also, if it is that risky to use Full programming, why not hide it? why even include it in the basic menu?, you could do something like making a separate menu for it and block using it without entering some kind of a code like serial number, for example...this way you highlight it as something not recommended for normal flashing!!.
    WOW...this is dangerous Paul. THANKS!!
    Great!
    If it is that risky to use Full programming, why not hide it? why even include it in the basic menu?, you could do something like making a separate menu for it and block using it without entering some kind of a code like serial number, for example...this way you highlight it as something not recommended for normal flashing!!.
    The tuner providing the tunes to the customer can set a flag in the *.ctd file that prevents full-flashing. So its really up to the tuner to "protect" their customers if they think the customer needs protecting.
  1. V2 storage case
    By GAMEOVER in forum FlashScan V2
    Last Post: September 24th, 2008, 08:56 AM
  2. SD card logging capacity
    By mistermike in forum FlashScan V2 BB Logging
    Last Post: May 5th, 2008, 03:05 PM
  3. Storage case
    By WILLIAMJRDN in forum Purchase and Shipping
    Last Post: February 18th, 2008, 03:24 PM
  4. Custom/DIY calibration definition file?
    By jimter in forum General (Diesel)
    Last Post: October 10th, 2007, 09:25 AM
